Was cutting fiber foam and it twisted around top wheel, cut off. I cut all the twisted fiber out of wheel and it won't start.
Maybe the bearing are covered with dust . Do a thorough clean up on it . Does it hummmm whenever you attempt to turn it on?
Thanks so much! I think it must be the motor ceased so ill take it into the shop! Thanks again for your help!
No problem .I am glad that I was able to help. Hope you'll get your band saw fix .
Oh please visit www.bandsawblog.com . You can read a lot of informative stuff there about band saw and saw blades. :)
SOURCE: Sears 12 in bandsaw vibrates when cutting
Are you sure the wheel bearrings are in good shape, and are all the screwws in the drive pulleys tight,including the pulley set screws.
SOURCE: Ryobi Bandsaw model EBW4023L will not cut straight
I do a lot of resawing with mine and I have found that a 3/8" wide blade gives me nice straight cuts.
SOURCE: MBS 240/E proxxon bandsaw
the 24 TPI is the one to use. It sounds as if the blade is running to fast and over heating the blade and causing it to lose the temper in the balde steel. Try slowing the blade speed down if you can. Also you can try putting some cutting oil on the balde to stop it from clogging up. You can also rig up a small air line to blow on the cutting area to cool it down and remove the metal chips. I've also applied some wax to the blade every so often. A candle will work for this too. Hope this helps you, Jeepfxr
SOURCE: Craftsman 12" Bandsaw Blade Tracking Problems
Sounds like you have a saw with defective castings. Either cast out-of-true or deflect under pressure.
It was my gramps saw and always worked great. I was cutting some 6in extremely strong fiber foam and didn't see it was twisting around the top wheel when it ceased up and the blade stopped . I cleaned it out real well and oiled the bearing.pluged it back in and nothing, the light didn't even come on. It s like you should hit a reset button but there isn't one. It makes no sound.Thanks for your help, tammy
There might be something wrong with the motor. You said that it is not really turning on and even the light too .
