Question about NetGear RangeMax WPN824 Router
Securing our wireless connection
Yes, my mother-in-law purchased a router for her laptop which is hooked up to my modem because I have comcast for my desktop computer. I just purchased a laptop my self and toshiba helped me connect to my mother-in-laws router. When I was about done the connection stated that it was a unsecured line. My question is how do secure the line. The router tech support wants to charge me to fix this problem. Evidently the router is out of its free tech support time even tho it is only a 6 months old. Can you help me with this problem?
  • Billy Marshall
    Billy Marshall May 11, 2010
    Read the users manual or post the modle so I can and help you out
  • 104 Answers
Hi … perhaps I can help..
There may be more than one way to set to set up security on this router. However, most routers accept manual configuration. There are four main steps to this:
1)Login to your router
2)Change the router password
3)Change the SSID, or network name
4)Enable WPA encryption.
Here the details (based on the Netgear Rangemax manual - if this is not your model, please check back):
Important note: use a wired (ethernet) connection to the router to set up wireless security.
1) Login to your router.
You have probably done this already, but here it is again for clarity. Type the router address in the address bar of a web browser. The default for this model is http://192.168.1.1 or you could try www.routerlogin.com (or .net)
You are prompted for the username and password. If you have not changed the password, enter username: admin and password: password
This should bring up the configuration screen/user interface.
2) Change the router login password.
Under Maintenance in the left hand menu, go to Set Password. Set and confirm a new password. Click ‘Apply’ when finished.
Tip: write this on a label and stick it to the router.
3) Change the SSID (network name):
Under 'Setup', go to Wireless Settings. You should see the Wireless Network Name,or SSID, at the top. Change this from the default, NETGEAR, to anything you like – as long as you can remember it. It is case sensitive, and you can use up to 32 letters – but don’t use something that could identify you, or your location. Click ‘Apply’ when finished.
4) Enable encryption
Still in the Wireless Settings menu option, you should see the Wireless Security Options section. You have a number of options for encryption. Select WPA-PSK: though strictly speaking, the correct option depends on your wireless adapter. However, this is a good choice to start with.
Under Passphrase or WPA Key you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HapPY2009toyou8892). It is case sensitive.
Note down the passphrase, or network key, carefully. You will need this to connect wirelessly. (The network key may also be called a WPA shared key, PSK, pre-shared key, authentication key, WPA key, WPA-PSK, security key). Click ‘Apply’ when finished.
That's it, you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you'll see the router with its new name in your 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if this doesn't work or if you need help with any of it.
Posted on Jan 07, 2009
Set up difficulties
You sure can. Start w/ the Comcast modem as long as it is NOT a USB type and hooks using a CAT-5 cable (regular network cable). Hook the comcast modem to the WAN port of the wireless router. On the back of the wireless router use the normal 1-4 extra LAN ports to hook other computers or the SD208 switch to it and other computers from there.
Word of advise if using Wireless Router, be sure to read manual and set a KEY for your network to secure it from unwanted outside use.
Apr 03, 2010 | Linksys SD208 8-Port Ethernet Switch...
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Is it possible to intercept a connetion from my mothers comcast cable modem to my wireless laptop
You also need a wireless router physically connected to the comcast modem so your wireless laptop will have something to communicate with.
Jul 03, 2009 | Computers & Internet
Trying to install router for wireless
If that's hooked to comcast you can only have one computer hooked up to it, and no modems as they block mac address. If you are a Comcast customer there is a workaround. Turn on your wife's wireless if she hasit, if not get her a wireless card USB is easiest. Turn on sharing on that wireless card and you will be able to access the internet through your wifes computer, and not run afoul of your Comcast agreement. Or request an upgrade to a wireless router from Comcast but your rent goes from $3.00 per month to $10.00!
May 12, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Connect Laptop to PC desktop which has cable connection.
YOU WILL NEED TO GET A WIRELESS ROUTER TO BE ABLE TO USE THE LAPTOP WIRELESS, iT IS A VERY EASY SET UP AND CONNECT THE DESKTOP WIRED AND THE LAPTOP WIRELESS TO A WIRELESS ROUTER.
May 06, 2009 | Arris SURFboard SB5120 Modem
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Loss of internet connection when going through router
Your laptop seems to be hooked to your neighbours unsecured network automatically and it is going online with that. About comcast, when you connect a router to the modem or a computer to the modem, the modem has to be rebooted to give a valid IP to the connected device. If the modem is not rebooted the computer or the router will get 192.168.x.x IP address which is called private IP address.
Nov 19, 2008 | Check Point (CPWSHCRA6500UUS) Router
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
NetGear RangeMax WPN824 Router Logo
88 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
