Question about Thermador UCV36A 36" Universal Cook 'n' Vent Downdraft Kitchen Hood
Range heating problem
I have a Maytag range that is only 3 years old. It would not heat up so I replaced the heating element. It now will heat up to 350 but it will not get any hotter. I'm also not 100% sure that it is really getting up to 350. What should I replace next? Or should I just call a repair man?
    Genius:
  • 2,920 Answers
If you already eplaced the heating element and its still no doing what its supposed to then its time to call in a repair man instead of 2nd guessing or changing part after part,,,
Posted on Jan 07, 2009
Maytag MIR8890AS0 6.2 cu.ft. induction range w/true convection. Takes an hour or more for oven to pre heat, doesn't maintain heat. 4 yrs old. Induction top OK.
I don't know, but it sounds like one of the heating elements are burnt out/no longer working. I had a similiar problem 5 years ago.. they're pretty easy to replace yourself if you are handy and have a screw driver. I think the one for my stove cost $18 to replace (5 years ago) here's the trouble shooting guide online for you model:
Maytag Range Stove Oven MIR8890AS0Troubleshooting Repair Help
Dec 07, 2016 | Maytag Kitchen Ranges
Only part of the heating element is warming up on the range.
You will have to replace the heating element.
Unplug the range.(Important step)
Remove the element from inside the oven.
2 screws at the back wall.
Replace the element.
Plug the range in and bake me some cookies.
May 11, 2010 | Maytag MER6772 Gemini Electric Kitchen...
I'm having trouble with the lower heating element not heating on my GE Electric Range. Its probably 10 + years old. The broiler element heats. Will I be able to replace the element or circuit board? ...
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
http://www.partstore.com/Content/CategoryPages/Kitchen-Cooktops.aspx
Or directly to GE
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Cooking%20Products
Dec 24, 2009 | General Electric Stove/Oven/Range Chrome...
Electric burner does not heat up.
The reason for Maytag electric burner not to heat up is that the heating element had exploded and there was white powder all over the inside of the oven. Replacing the heating element will make it work.
Also would recommend having the following cross verified:
· Element terminals have loose connections? Reposition the element.
· Range element shorted out? Find out by testing; replace if needed.
· Burner switch is bad? Find out by testing; replace if needed.
· Element receptacle bad?
Thank You for using Fixya.com
Jul 28, 2009 | Maytag Gemini® MER6765BA Electric Kitchen...
Single element in 3-way burner won't work
Hey Janice,
Sorry to hear this.. but, here is a site that will answer your question more completely.. ( I think this is a complete replacement job).. and if your are mechanically inclined, you might be able to do it yourself... good luck,,
as far as costs... that's such a wide range of "prices per hour or by the job", it would not be feasible to put a $$$ figure on here..
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/94552-glass-surface-triple-element-replacement.html
Jun 19, 2017 | Maytag MES5775BAF / MES5775BAN /...
Problems with Maytag MER6772 Gemini Electric Kitchen Range
may tag gives 5yer worenty if not still under worant get rid of it
Apr 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Stainless Steel & Black Electric Oven won't heat over 140 degrees
on a 220 volts stoves when the electrissity drops to 120 volts thats what it does.so oven element wires most be check for power, if it's getting 220 replace the element.
Sep 16, 2008 | Maytag MER5755QAS CleanDesign Electric...
Maytag gas range I'm not sure of the model #/range is nine years old
YOU OVEN IGNITER IS PROBABLY ONE STEP AWAY FROM GOING OUT.
SO REPLACE IT AND YOU SHOULD BE UP AND RUNNING.
Jan 15, 2008 | Maytag MGR5751AD Gas Kitchen Range
Electric oven does not heat up enough
I had the same problem before the warranty expired. The heating element had exploded and there was white powder all over the inside of the oven. They replaced the heating element and it works as it should, however, this oven has never baked right. It gets hotter on the right hand side than it does the left and I have to constantly watch whatever I bake. I'm not very happy with this oven.
Apr 27, 2007 | Maytag MER5755QAS CleanDesign Electric...
Kitchen Ranges Logo
130 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
