Question about Dell A920 InkJet Printer
Downloaded drive for Dell A920 Vista but it still won't print
I have downloaded drive for Dell A920 vista compatibility but it still wont print and wont change its status from offline. Have right clicked on offline but it gives no prompt for online.
  • 1 more comment
  • jamescdaly Jan 10, 2009
    I tried your solution and while it printed a test page it then refused to print any further pages. The printer status in the control panel continues to tell me it is offline but when I right click on this the prompt is that the printer can be put offline which suggests that it THINKS IT IS ONLINE and so is giving me no option to put it online. it is storing the printed pages but not printing.
  • jamescdaly Jan 11, 2009
    The problem remains. The printer is communicating with my laptop but its status remains 'offline' This is its status also when I right click in the control panel mode as the only option is 'offline' Very frustrating as I know it is communicating with the laptop.
    The problem remains. The printer is communicating with my laptop but its status remains 'offline' This is its status also when I right click in the control panel mode as the only option is 'offline' Very frustrating as I know it is communicating with the laptop. What a pain Dell is proving to be!
    Master:
  • 416 Answers
You might try bypassing the print spooler to see if that avoids the
problem. Right mouse click on the printer in Settings / Printers and select Properties. Depending on the printer there is likely to be a setting: Print direct to printer. Try it and see what happens.
Also the problem of Vista and printer always offline might be solved by uninstalling Adobe Reader
Good Luck
Posted on Jan 11, 2009
    Brigadier General:
  • 5,158 Answers
Go to your start menu... in the box type printer... when that box pops up... locate your printer... first make sure it is the default printer.... then right click and from the pop down menu select properties.... make sure the printer shows online there
Robert
Posted on Jan 10, 2009
    Sergeant:
  • 378 Answers
Disconnect the printer from the pc for a minute and reconnect it asgain and check out.it should work.
  • Dell Master
  • 6,487 Answers
Try to power off the printer for about 1 minute and disconnect the usb cable from your computer and after a minute connect the usb back and power on the printer, but if still check the printer under device manager and you may need to manually reinstall the printer driver..
Posted on Jan 09, 2009
  • Dell Master
  • 19,396 Answers
Unplug printer USB, and reinstall the driver.
This time when you reinstall the driver keep printer unplugged and do the following:
Locate the driver installer file.
Click right button of mouse on installer file.
Chose 'run as administrator 'from dropdown menu.
Start driver installation with printer USB unplugged.
Connect printer usb only when asked by setup wizard.
Chose printer as default printer during installation
    Sergeant:
    Champion:
  • 435 Answers
Hi, Uninstall the driver. switch off the printer. Disconnect the cables.
Restart the computer. Install the driver. Restart the computer. Connect the printer and switch it on. You may have to restart the computer again. It should work now.
I assume you are using correct drivers.
  • Karthik P Jan 10, 2009
    Ok.
    Try this.
    Switch off the printer.
    Delete that printer which says 'offline'
    Switch on the printer.
    Now the New Printer icon should come up after some setup wizard.
  • Dell Master
  • 13,433 Answers
Reconnect the printer, you should hear the usb connect sound, it should install the printer automatically, try printing again.
Also restart the laptop and reinstall the driver if noting happens.
Also look into the device manager right click my computer select manage, then on the left side select device manager. see any yellow ? or ! marks?
  • 716 Answers
Power Off Your Printer Hold The Power For 20 Seconds Then Release? Also To Confirm You've Restarted Your Computer Since Installation?
    President:
  • 2,110 Answers
Your printer is not communicating with the Operating System.
First uninstall the printer. ( Make sure you have the printer driver disk )
Make sure the printer is OFF and disconnect the power lead to your desktop or laptop.
Leave the computer OFF for 2 to 3 minutes. I actually mean turn it off and disconnect your power cord to the computer. That will clear everything.
Plug in and on your computer and let it boot up. When its fully booted, click START / SETTINGS / PRINTERS and FAXes and click ADD A PRINTER.
Follow the instructions and have the appropriate driver disk or files on your computer to complete the installation.
Remember, most installations require the printer NOT be powered up or connected while you load the drivers. That is normally the last step and the driver loading will prompt you to turn on the power and make the connections.
Then you probably will have to reboot and voila, you're done.
Is there a windows 7 driver for the A920
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell A920 All-In-One Inkjet Printer owners thread (W7)
Remember virus programs and firewalls will block communications.
Rick
Oct 19, 2011 | Dell A920 InkJet Printer
I have a dell printer A920 and an acer computer with windows 7. Having trouble getting the printer to work
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
Download and install the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block communications.
Rick
Apr 18, 2011 | Dell A920 InkJet Printer
Windows 7 were can i download the drivers for windows 7
Unfortunately, according to Dell's website, it looks like the A920 InkJet Printer is not compatible with Windows 7.
You could download earlier drivers for that printer from this page though (for Windows 2000, Windows XP and Vista).
May 28, 2010 | Dell A920 InkJet Printer
My dell a920 printer won't print with windows 7
Hi There
Not no if you may have the wrong driver, this one is for Vista and most Vista drivers will work on Windows 7 gave it a go.
I have put a driver for you on my website for you it for windows Vista to download just click on the driver link and it will download for you, best to save it to your desktop so you can find it.
Link = http://www.4all2sell.com/driver/Dell-A920-Vista.exe
After you have downloaded it just double click on the icon Dell-A920-Vista.exe and follow the instructions to run the.
Please call back to say if it works for you Thanks
All The Best: Pineworks
Feb 11, 2010 | Dell A920 InkJet Printer
I've never been able to print using the a920 on my computer using vista. It prints perfectly on other computers, though. It starts up, acts like its printing a page, but the page comes out blank. In fact...
u need to uninstall the drivers for the printer on ur vista computer,.. go to the following link and download latest vista drivers..
it will work..
Dec 20, 2009 | Dell A920 InkJet Printer
Networking a920 printer with vista
The Dell A920 all-in-one is only compatible with Windows 2000 or Xp, if you are using Vista you will need a different system.
Jan 02, 2009 | Dell A920 InkJet Printer
Dell A920 with Windows Vista
For a Dell A920 (Personal All-in-One), pls download OS appropriate driver(s) from here. Pls select Vista, thereafter, install.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 21, 2008 | Dell A920 InkJet Printer
Believe it or not... the driver is buried on the Dell site for Vista 64-bit. I search and searched ... and there it was.
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R153048&formatcnt=1&libid=0&fileid=203948
In any case, I downloaded it, installed it, and it works fine. All the buttons (scan/copy) on the top work as well as printing. Now if I could just get my old XP machines to print to it on the network. But.. I think that is another thread.
Oct 27, 2007 | Dell A920 InkJet Printer
Dell A920 InkJet Printer Logo
23 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
