Question about Dell Dimension 1100 PC Desktop
Dimension 1100 desktop problem after reinstallin ram cards
I have a dimension 1100 desktop that i took the ram out of to try some "freebie" ram and when i seen it wouldnt work ..i reinstalled the original cards in it.. i know they are in right and i tried one at a time(i have two 512 cards) and i even switched the slots they are in; still nothing. i have tried reinstalling them a bunch of times but all this done was stop the beepng that was coming on when i started pc(this started when i tried at first to reseat the original ram). now the mnitir wont come on but a second and goes back to yellow on the power light,
  • 7 more comments
  • Anonymous Jan 07, 2009
    not shapot sound drivers for windos vista
  • vengance Jan 08, 2009
    we found the coms battery and are not sure where the jumper is you are refering too can you give us the color/size/or description.
    how about a picture.we are afriad that we are going to mess up the computer
    two jumpers located near the cmos battery.
    one has two rows of pens the other has a single row of pens
    took each off but has exactly same number of prongs as jumpers so..could not move too outer two pens. is it the double row jumper or single row jumper. also since rehook jumper after lookin at it, computer beeps when starts up and monitor still wont come on
  • vengance Jan 10, 2009
    is it possible for both ram cards to go out at the same time?
    i found out the problem from dell techs. its the motherboard. said neither slot is detecting memory. so now i have two one gig cards that wont be any use and two 512 cards. im not sure what ddr2 will fit ..but that was the ram that was given to me(2 1 gig cards). oh well thanks for the help and ideas.
  • JDTec
    JDTec May 11, 2010
    ANS: Possible but not likely.
    Did you clear CMOS?
    Take all boards out of the unit, leave. Then restart and see what happens.
    BTW, Never force the Ram into the banks. they should snap in easily!
  • JDTec
    JDTec May 11, 2010
    The pin header should be labeled "CMOS clear"
  • JDTec
    JDTec May 11, 2010
    I could not find a diagram of your PC. But I found the service manual. Look at the section under "Battery".
    With the power off and power cable disconnected:
    Take the battery out per instructions, them take a screwdriver and short the two metal tabs for about 10 seconds. Put the battery back in and power up the PC. It should start ok, that is unless something happened to the motherboard when you switched Ram.
    http://support.dell.com/support/edocs/sy...
  • JDTec
    JDTec May 11, 2010
    Look at the CMOS battery (size of a quarter), near it you should see a jumper to clear CMOS. move the jumper from the pins it is on to the 2 outer pins. Keep it there for 30 seconds, then put the jumper back on the original pins. This will clear CMOS then make sure your original Ram is seated correctly before you turn the PC back on.
    Let me know if this corrects the issue.
  • 31 Answers
You may have fried the original RAM by using improper installation techniques (no static provisions) or you may simply not be seating the modules properly, it take more force to put them back than you might realize. RAM is very specific to proper fit (voltages, etc.) Freebie RAM is rarely free.
Posted on Jan 07, 2009
Dell Dimension 1100 hard drive activity light on constantly and hard drive making noise, lagging
Try to create an other user and login with that user, then check if the issue still happen.
Jan 03, 2013 | Dell Dimension 1100 PC Desktop
Ihave adell dimension 1100 and since yeserday my pc has not cut on i have took everything out tested and everything but it seems to still not turn on anybody can help me?
Check the Diagnostic LEDs on the system, see if they give you an indication.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
If you still cannot ID anything, I'd try a replacement power supply 1st as that is about the least expensive item
Apr 17, 2010 | Dell Dimension 1100 PC Desktop
Primary disk 1ot found
Does your computer completely load up after getting the prompt?
And
You have to make sure that your ram is all the same. If it is a custom computer and you bought the different parts, your ram cards could be different, the motherboard for your computer requires a certain ram cards. All are different so i wouldn't be able to tell you which one your computer needs. You would have to find the one that works and see which it is ex. PC 100, PC 3100 etc.
and if thats not the problem then either the card slots in your motherboard could be bad or just the cards could be bad.
Mar 21, 2009 | Dell Dimension 1100 PC Desktop
Removing outer casing of tower ?
remove outer case of ur cpu white cable will there inside place ur dvd in the top of the cpu connecvt the cables
Jan 30, 2009 | Dell Dimension 1100 PC Desktop
Dell Dimension 1100 PC Desktop Logo
70 people viewed this question
Alun Cox
