Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The piece were the cable is connected to is broken
And the image is unclear and blury when you turn it on the model is d52w15 rca tv 2003 i wanted to know the neme of the piece or what can i do to fix the tv
  • Anonymous Jan 08, 2009
    Same date and problem. I tried to sauder the small nut back on the silver box and Icould not line the nut back on the box. I tried to put the jack back into the silver boxa nd it was not lining up straight. My question is can I replace the antenna/cable (silver )box. Are these parts available to replace after market for this TV?
  • 28 Answers
Must replace the tuner call union electronics they probably have it
Posted on Jan 09, 2009
HI I HAVE A RCA D52W15 BIG SCREEN AND IT HAS A BLUE IMAGE IN THE LEFT SIDE OF THE SCREEN WHAT COULD CAUSE THIS ANY INFO WOULD HELP THANK YOU
Might be to the fault to degaussing. Contact any service technician. If you wish to get more details, check the site linked here
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 09, 2013 | RCA D52W15 TV
D52W15
this tv does not have bulb or lamp it has 3 picture tubes red,green and blue
Oct 23, 2012 | RCA D52W15 TV
Replaced convergence board, fixed problem, and now want spare.
The usual order of probability I have found is:
Semiconductors
Electrolytic caps
Regular caps
resistors
inductors/trnasformers
Static testing OFTEN will not reveaal the failure.
Dec 31, 2009 | RCA D52W15 TV
D52w15 comes on then shuts off
Hi, thank you for visit fix ya.
This is a common problem on this kind tv.
Replace capacitors on power supply.
22000 uf 16V and 220uf 16 V; upgrade to 35V.
For parts, go to:
http://www.encompassparts.com/
Any question I will be here.
Thank you
Jul 28, 2009 | RCA D52W15 TV
I get a red screen on my rca d52w15 tv. It is only 3 years old.
Have you took back off to see if all 3 of the tubes are lighting up R-G-B Tubes? These sets Sold for $1,000.00 and up.
Dec 28, 2008 | RCA D52W15 TV
Rca hd tv d52w15
that model is famous for having bad flybacks. fortunately they arent exspensive and there easy to replace. you can get a new replacement at the following link for less than 50 bucks and they give free instructions on how to install it properly.
http://servicemanuals.vstore.ca/
Jun 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch hdtv model D52W15
Blue CRT has shorts that causing the set to go into protective shutdown.
May 01, 2008 | RCA D52W15 TV
Rca d52w15
Most likely a bad flyback. It's a cheap part, but service people are even having a harder time getting ahold of one since they are failing often.
Apr 01, 2008 | RCA D52W15 TV
Rca d52w15
Possible short and safety is keeping the set from burning up. A service man should be able to find the short hopefully in a small amount of time.
Nov 05, 2007 | RCA D52W15 TV
Rca hd model #d52w15
That flashing means that the sweep power supply didnt start up along with the main power supply. It could be a shorted horizontal output transistor or a bad flyback transformer. Youll need a service manual to scope out the horizontal drive and see why itsnot starting up or staying on. if your not a servicer then there are no real user serviceable parts inside so contact your local AUTHORIZED servicer as they will have all the right service manuals as well as acess to all the proper parts. Not that an unauthorized shop is a bad thing its just they the unauthorized usually are not aware of troubles that rca sends there peeps. Good Luck
May 28, 2006 | RCA D52W15 TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
