Question about Toshiba 20HLV86 Television
Toshiba 20hlv86-No picture
Given a Toshiba 20hlv86 by friend, but the unit has no picture, no menu, although the screen lights up.
2 Suggested Answers
  • 16 Answers
SOURCE: Toshiba 20hlv86 TV/DVD Combo - DVD not working (not spinning up)
maybe the pick-up has gone,or dirty len?spin motor gone?
1,clean the len
2,replace the spin motor which hold disc
3,replace the pick-up assembly
Posted on Mar 30, 2009
What is the code for toshiba 20hlv86, want to program universal remote
1070,1084,1004.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electromedicals.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 15, 2014 | Televison & Video
Toshiba theaterwide hd tv 20hlv86 hdmi
What is the problem you faces with this TV. Provide more details, please.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 02, 2014 | Toshiba 23HLV86 23 in. LCD TV/DVD Combo
I have a Toshiba Regza 32lv 703G lcd tv. I switched it on and I have lost my colour. It only displays in black and white although the menu screen is till displaying in colour. Kindly advise. Thanks!
It is pretty much junk, sorry to say it but your picture tube went out and it is cheaper to buy a new t.v. My grandpa use to fix them for us for free but he passed:( If you call some where see how much they would charge for a picture tube, I bet it's expensive???
Jan 15, 2012 | Toshiba REGZA Televison & Video
I turn the TV on. Then about 3 minutes later the picture goes out but the sound is fine. I turn the TV off, then back on. The picture returns only to cut off againg.This happens when viewing the in TV mode...
When picture goes away do you see the screen still emitting light or does it go completely blank?
Depending on the answer there are two possiblities:
if the screen goes completely blank then the problem is likely in the TV's inverter and more specifically very likely in some of the high-frequency transformers. Best solution there is replacement.
Unfortunately inverters are often on one board with power in smaller TVs.
if the screen is still emitting light albiet being blank then the problem is more likely in the main board and, less often, in a cable.
Main boards often overheat and ICs relying on soldering contact bonds of 1/10 sq.mm. start misbehaving in all kinds of ways , including like you describe.
There's no simple cure for that problem - usually it's cheaper to replace the whole board or even the whole TV than to troubleshoot it.
Perhaps not great news, but that's what I know about it.
Bobby
http://www.coppelltvrepair.com
Jan 23, 2010 | Toshiba 20HLV86 Television
1,clean the len
Mar 30, 2009 | Toshiba 20HLV86 Television
Projection lights
You need to take the Toshiba remote that came with the machine and go into a menu area that deals with convergence. Here's what the manual says:
This TV used 3 separate TV tubes, red, green, and blue. The R, G, and B images are pojected onto the screen wheree they converge to form a full-color picture. You can see a clear picture only when the three images converge correctly. Corvergence my drift over time, or if yo move the TV. I you can see clear images on your TV screen skip this procedure.
Make this adjustment only after the TV as been on for at least 30 minutes.
Press the TOUCH FOCUS (auto convergence) button on the front of the TV at the bottom.
The TV will enter into the convergence mode and adjust the converge automatically (that's what it says.)
TO ADJUST IT MANUALLY:
Press MENU, and the press < or > until the PICTURE menu appears.
Then press UP or DOWN to highlight CONVERGENCE.
Press < or > to display the Center Convergence menu
There's a lot more the book says, but, I can say from experience that you just go through the different sub areas of this menu and converge each color separately, and bingo, it's fixed.
Good luck.
Sep 06, 2008 | Toshiba 43H71 43" Rear Projection...
Broken screen
all you can do is chase a used
Toshiba (Theater Wide HD) Model NO.20HLV86
or buy a replacement TV
was it covered under contents damage insurance ?
this TV has been discontinued
the design of this screen means its put together
layer by layer .sandwiched ..not just a glass cover
a screen replace can't be done
unless the Toshiba company "TV parts division " has the exact same screen to supply to your local TV repair man
Even finding circuitry boards to be supplied for that model have a slim chance
Apr 11, 2017 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Televison & Video Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
