Question about Linksys Wireless-G Broadband Router
I connected the cables to my Linksys WRT54G Router and to my DSL
Box according to the way the advisor advised me. All lights on the Router came on except for the wireless-G or WLAN light--all cables were checked and tripled check--no WLAN light.
  • 192 Answers
Type ip adress in the browser it may ask for a user name and password after enering that you should be able to get online.
Posted on Jan 07, 2009
DEAR SIR/MADAM TO WHO IT MAY CONCERN I HAVE A LINKSYS WAG325N ROUTER , I did REST IT ALREADY i GOT THE POWER LIGHT GREEN THE DSL GREEN THE WIRELESS GREEN BUT THE LOCK (SECURITY) IS YELLOW/ORANGE AM...
connect direct to the router using a cable connection then try accessing the routers setup page again you must be connected before you can access.. also i noticed its a "N" type router and if your pc doesnt have the drivers for an N router then its sure to cause problems..
Feb 12, 2011 | Linksys Wireless-G WRT54G Router
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
No internet connection to main computer when router connected
If you are getting lights on the Internet LED. Go to the router's setup page 192.168.1.1 and put in your username and your password if you are on DSL. For cable connection try to reset your router by resetting the router
Jun 04, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
Hooking up wireless linksys
From ethernet of embarq plug it to the Internet port of Linksys. Your PC should be connected to port 1 of Linksys
Aug 17, 2008 | Linksys Wireless-G WRT54G Router
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Dec 08, 2007 | Linksys Wireless-G WRT54G Router
The Computer doesn't recognize the Router (And Yes. the wireless switch is turned on)
DON'T use the software.
Are you trying to connect by way of ethernet cable or wireless?
Either way you do it, you do NOT need that crap software. 90% of the time, that software interferes with everything. Up to AND INCLUDING preventing your system from connecting to the router.
Before you can get any help with this, you will need to give us more information about your setup.
NOTE: We CAN NOT POSSIBLY figure out all of the variables if you do not give them to us. So don't go marking my post as "Thanks for trying" just because your problem is not solved in the first post.
Instead, if you want answers, you're going to have to be more specific.
I see a Linksys WRT54G wireless router. Is there a version number on there?
Example: WRT54G v3 (Mine.)
You're also going to have to tell us more about your computer. Is it Windows XP? Service Pack 1/2? Windows Vista? Linux even? (Give model numbers if it's a pre-built system from an OEM manufacturer such as HP, Dell, etc.)
Then there's the internet connection. Cable internet? DSL? Satellite? Give us MODEL NUMBERS of the equipment they have issued to you for your internet connection.
Then tell us how you have things connected. Wireless? Ethernet cable? What is connected to what?
See what I mean?
FULL details bring quicker resolution of your problem. I will be monitoring this post as you seem capable of providing this information to us. When I see more complete information, I will help you further from there.
Thanks. :)
Cyryl
Nov 21, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
172 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
