Question about Kingston 1GB PC2700 DDR SoDIMM Notebook Memory
Memory Installation I removed my two 256K and tried to install two 1G DDR PC2700 memory cards onto my Toshiba M45 S169 laptop. When I did, all I got is a blank screen for a few seconds and then it shuts down. This is after I hold the power on button for 10 seconds. I then reinstalled the two 256k memory chips and get the same thing. What can I do?
  • 47 Answers
Look at the hardware documentation and look for a bios reset switch.. that should make the pc usable again.. then i would suggest.. trying a slower ram module.. ie 2300 might work..
Posted on Jan 09, 2009
Toshiba satellite m45-s169 will not boot windows
Windows is corrupted or the hard drive has issues, if you have a cd installation disc try a fresh install, if no change! the hardware needs to be checked for possible replacement.
Apr 14, 2012 | Toshiba Satellite M45-S169 Notebook
How do I replace RAM in toshiba satellite M45-S169
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1042107&rpn=PSM43U&modelFilter=M45-S165&selCategory=3&selFamily=1073768663
This is your manual. There is a cover on the base of the laptop.
Take the screw out, take the cover off, there should be a spare space for the memory module.
You push the memory in at a 45 degree angle and gently push down till the clips lock it in place.
You may use a maximum of 2gb ram in 2 1gb sticks.
you will need pc2700 (ddr333)
Amazon has some cheap memory here
http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=sodim+pc+2700
Jul 10, 2010 | Toshiba Satellite M45-S165 Notebook
Changing the ram in my toshiba stellite a45 laptop
I don’t have a diagram for upgrading memory in this particular model, but it’s very easy. You can access both memory slots from the bottom of the laptop if you remove the memory cover. The cover is located in the middle, right beside the fans. All you have to do is remove 2 screws and remove the cover. I believe Satellite P15 memory is expandable to 2GB in both slots (Slot A + Slot B = 2GB) and you can use PC2100 DDR RAM, PC2700 memory should work too (it will run at PC2100 speed).
Check the laptop specifications before you buy new RAM module. I just discovered that different Satellite P15 models use different memory types. For example, according to Toshiba specifications Satellite P15-S409 uses PC2100 DDR memory, but Toshiba Satellite P15-S479 uses PC2700 DDR memory (I think it might be a typo, but not really sure).
Jul 31, 2009 | Toshiba A45-S121 Notebook
Which memory cards fit Toshiba satellite M55-S331? I want to add 1G, and I understood it might not work with some of them.
Here is the RAM specs for your notebook:
Installed size: 512Mb / 2Gb max Technology: DDR SDRAM 333MHz, PC2700
According to this specs you can reach 2Gb max so you won't have problems with 1Gb... just be sure you use the same technology
cheers
Jul 27, 2009 | Toshiba Satellite M55-S331 Notebook
Toshiba laptop a75-s209 maximum memory capacit 2.5 mb
1.5GB total maxium, if I read the toshiba litature,correctly. So the answer is no, you may not. THe BIOS will only be able to read and use the max it was programed to read.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=835414&rpn=PSA70U&modelFilter=A70-S259&selCategory=3&selFamily=1073768663
Jun 29, 2009 | Toshiba Satellite A75-S209 Notebook
Satellite M45-S169 - will not POST or power on. Power light comes ON for a few seconds then goes OFF. Power ight cycles ON/OFF six times then stops.
Hi rich caller i had this problem also with my laptop toshiba satellite M45-S169 and i find solution for this problem..
Just replaced ram memory and now my laptop works fine hope yours will work too
please respond if my msg helped you..
regards
Bess
Apr 03, 2009 | Toshiba Satellite M45-S169 Notebook
Memory upgrade
The M45-S169 only has one available memory slot.
(I'm confused about your post that states "M45-S265" in the head line).
  • Configured with 512MB DDR SDRAM (both memory slots may be occupied)
  • 512MB(min)/2048MB (max), 256MB on-board memory with 1 available memory slot for 256MB, 512MB, or 1024MB PC2700 DDR 333MHz SDRAM 2.5V SODIMM memory modules
You can find the complete specifications here.
Jan 05, 2009 | Toshiba Satellite M45-S265 Notebook
Cant Start Up
Hi
start with removing the added ram try starting up, if it doesn\t start up does it beep?
if noting happens remove all the ram, the computer should definitely beep now.
Add only the original memory and try starting up you should get picture.
This seems to be a old problem and if you don\t need assistance in solving it. It would be great if you would share to the world how you fixed your problem so other users can benefit from your experience.
Thank you, Ekse
Sep 28, 2008 | Corsair Memory Value Select 1GB PC2700 DDR...
How do install memory on tosiba laptop model M45-S169
Hi
Just click on this link for instruction, click HERE
The middle part of the laptop is where the memory is- usually it has a cover for it that you can remove. Hope this help.
Thanks for using Fixya!
Jul 11, 2008 | Toshiba Computers & Internet
Dead Toshiba Satellite M45 S-169
hi dear
maybe you can try to check your memory module
release your memory module, use am eraser to cleaning your memory. and install it again
ok
Mar 23, 2008 | Toshiba Satellite M45-S169 Notebook
Kingston 1GB PC2700 DDR SoDIMM Notebook Memory Logo
100 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
