My prolectrix usb turntable won't play properly
My 3 speed usb turntable is only playing about 12 seconds of a track, then stopping and returning to the rest position. any help would be appreciated
  • Anonymous Jan 08, 2009
    I am having the same identical problem and cant get the co to return my calls.
I also have the same problem, im sure its something to do with the tone arm, like at the start of playing a 12'inch you have to hold the arm at the end of the vinyl for 5 seconds, have i answered my own question, i'll let u know ......
Posted on Jan 08, 2011
I am trying to play a record on my Aiwa LX-120 turntable but after scanning the record the arm won`t go down.
I'm not certain that you are meant to disengage the FG lock since this means that the turntable has achieved the correct speed. The problem you have is that the arm won't go down.
I don't know to much about the workings of this direct drive turntable. But I can say you can get the service manual free on-line if that helps.
May 01, 2015 | Aiwa Audio Players & Recorders
Why does my lenco l90 turntable cut out when near the end of playing a 45
If you search Google for the model manual you will find a PDF of it.
A quick look at it says turn the auto return switch off.
Aug 20, 2014 | Audio Players & Recorders
How can I stop the tone arm from returning too early on smaller records?
Type Crosley Model # of your device user manual " into search engine and it will show sites to get manual. In it there might be a way to help you
Jun 14, 2014 | Crosley 0187SST Turntable
Crosely won't play usb
If it's a turntable with a usb connector, those connections are usually outputs only. USB on a turntable is used to output the audio to a computer to rip albums to digital audio.
Jun 17, 2013 | Crosley Audio Players & Recorders
Even though i am playing my record on normal speed, it plays to fast
if your turntable doesn't have a pitch control (like the dj's turntables) if you open it you should find on the board close from the 45-33 rpm switch a variable resistor ( a small electronic part with a sort of disc on top with in the middle of it a place for a flat screw driver and marking like + and - those resistor are made to control the speed and can go bad or just need to be adjusted . First try to adjust it turning the dial really carefully with a small screw driver if nothing happened it could need to be replace.
Feb 03, 2013 | Mutant MIG-MT201 Record Turntable, 33...
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John
Nov 28, 2011 | Audio Players & Recorders
When im playing my vinal it come out in stereo but when i download it to the computer it plays in mono what im i doing wrong the system i have is prolectrix usb three speed turn table hope you can help...
if you open edit/preferences in audacity you can select the stereo option, make sure that windows/control panel/audio out is set for your pc sound system and not the usb turntable, as was in my case, there is no speakers on that.. jacko
Mar 05, 2009 | Teac DRH300DAB Receiver
I have new Prolectrix turntable USB Direct and tone arm leaves record before end of playing record. Hope you can help. Thanks
Turning the return position adjustment (the flat black-headed screw next to the tone arm) a little clockvise will probably fix your problem.
Jul 06, 2008 | Audio Players & Recorders
795 people viewed this question
