Question about Estate TEDX640JQ Electric Dryer
Dryer takes two sometimes three cycles to dry clothes
I have checked the lint trap and hose to outside.
  • sndtechie May 11, 2010
    Is your dryer gas or electric?
  • 706 Answers
Hello kingbeezer,
Assuming you have no blockage or restrictions in your duct system, does your dryer get hot and do you have a reasonable air movement coming out of it when it is running? You may have a bad blower or something restricting air flow within the blower. Another consideration is How hot is it getting inside the dryer? If its electric, the heating element may be starting to fail..or if its gas, the gas burner may have jets blocked or not getting adequate gas for a normal flame.. Just siome thoughts.. You really should provide brand and model number when you post a question.. It helps us help you and provide model specific answers...
Good Luck
Rick
Posted on Jan 09, 2009
Whirlpool lg6099xsw1 dryer has to go through multiple cycles to dry clothes. Does put out some heat, but for whatever reason the clothes are not dry after the first cycle. This has not happened before
Remove the back of the dryer remove blower housing that goes to the lint trap proablly clogged also check dryer vent and hose leading outside for blockage
Nov 16, 2012 | Dryers
Clothes not being dried in drying cycle. Fan is working.
Your washer dryer will only dry half the clothes that it can wash, so you may need to reduce the amount your trying to dry. Also the drying side works by condense drying,it wont be vented outside, it needs a trickle of water which runs behind the draw where you put the powder in. When its on pull out the draw and check that there is a trickle of water going in, if not it's the solenoid valve gone, not a major job to change, and it is a fairly common fault. Have you checked the hose that leads to outside? They get stuffed with lint,etc and sometimes they need to come off the dryer and the blockage removed, or buying a new hose could be necessary. Check the exit point on the machine and the entrance and exit point in the wall of the building. Make sure your lint trap is the machine in clean and it should be washed every three months.
May 17, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Dryer takes too long to dry clothes. Heating element is working because clothes are hot but it takes almost 2 dry cycles to dry clothes.
It sounds like you're lacking air flow. I'm sure you're cleaning the lint trap / filter - but have you clean the VENT HOSE / PIPE?
The 4 in vent hose is supposed to be cleaned annually. If you have the flexible vinyl hose, replace it with either steel, aluminum or flexible aluminum tubing instead. Once you've removed the vinyl hose, it will collect a lot less dust and can be cleaned without worry of puncture.
A typical dryer vent brush.
Make sure there's no obstruction to the flap outside, too. Once cleaned the dryer operation should be restored to new again.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 09, 2011 | Dryers
Takes 3 cycles to dry clothes
This is a potentially deadly scenario. If the clothes are warm but just not getting dry, there is a problem with air flow - specifically - the lack thereof. The chance of fire is a real concern.
Make sure the lint baffle / trap is clear. This should be checked / cleared after each drying cycle. Most folks know about this, but I included it just in case this is your first dryer.
If the the baffle / trap looks clear, the exhaust tubing of the dryer is suspect. Many installations consist of the flexible / expandable hose. This hose may have become crushed during the running of the dryer, reducing air flow. Locate the hose and pull the dryer away from the wall to inspect, expand or replace the hose as needed. If an old installation, it is very possible that the hose has become clogged with lint build up over the years. The hose should be replaced in this case.
If at all possible, use aluminum expandable dryer duct. It is less likely to collect lint as quickly as the flex plastic style.
If the clothes are not warm or hot, the heat source (electric heating element or gas flame - depending on type) has a problem. Either of these problems should probably be referred to a pro for proper repair.
Jan 20, 2010 | Kenmore Dryers
My GE dryer takes 3-4 times as long as I expect it to to dry my clothes. I've read that it should take about 45 minutes to dry a load but after the first cycle the clothes are still damp. It usually takes...
You have checked a lot already ... thanks for the comlete story. Often the questions here hurt for detail.
Are your clothes getting hot?
Two reasons for not getting dry ...
No heat
No air.
You need warm air (heat and air) going through your drier to achieve dryness.
Sounds like you have no heat. Are you properly setup on the control panel (you selected heat)? You have physically inspected the entire exhaust sustem including the outside vent, hose and lint trap - absolutely clear ...
check the heat my friend
Oct 20, 2009 | Dryers
Dryer does heat but takes 3 hours to dry a medium size load of clothes
Sounds like the moist air is not being properly vented. Your dryer has a fan that pulls in dry air and expells the moist air. This is vented thru your dryer hose and should be vented to the outside of your home. Sometimes the hose will get either a blockage or a partial blockage that will make it either not dry your clothes or take longer than it should. I have seen hoses that have a sag collect water much the way your trap will under a sink. You can either throughly clean the hose, and check for a blockage in the hose or the dryer itself, or you may, as a test, disconnect the hose temporarily and vent your dryer into an old pair of panty hose. When you turn the dryer on, the panty hose should inflate. Also make sure you keep your lint trap clean...EVERY LOAD.
Oct 02, 2009 | Amana DLE330RAW Electric Dryer
Clothes not drying even after 4 cycles
you have to check your dyer vent hose and vent pipe to outside for any restrictions. #1 problem for extented drying time. it like having a backed up sink
Dec 13, 2008 | Maytag PYE2200 Dryer
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
Takes two cycles to dry anything - even on High
first, check your breakers for the dryer. turn them all the way off and then back on. if it still doesn't work right, it needs to have all the lint cleaned out of the exhaust hose, and then the inside needs to be cleaned and the heating coil examined for damage.
Apr 29, 2008 | LG DLE5932W Electric Dryer
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Estate TEDX640JQ Electric Dryer Logo
136 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
