Question about Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome...
The lever will not stay up - Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome...
  • 1 more comment
  • jerij2001 Jan 10, 2009
    I understand I need a new cartridge but how do I get the lever off? I don't see any fasteners or anything.
    Thank-You
  • pachyderm Jan 21, 2009
    I'm having the same issue. I'm a plumbing idiot and can't seem to find the installation manual. If anyone can post a "how do I get the cartridge out b/c that's why the lever won't stay up when you turn it on" guide or link to such a guide, please let me know.
  • Anonymous May 01, 2009
    I have the same problem: the lever don't stay up. It's been told that need to change the cartridge, but how do I take the lever apart? where ca I see a parts/assemble diagram?
    Thanks.
    Novelist:
  • 148 Answers
The cartridge is worn
Solution: remove cartridge take to hd or lowes or ace and match up with new and replace
Posted on Jan 07, 2009
Throttle control lever won't Stay put
tighten up the screw that is the throttle lever pivot
May 07, 2016 | Garden
Rear brake lever sticking making my brek lights stay on
Hi, There should be a spring that pulls the lever back up when you remove your foot. It might be missing or broken. You might also have a mal adjusted switch that activates the brake light. it should be located near the pivot bolt for the brake lever. There is also a switch on the front brake lever. That might need adjusting or replacement.
May 21, 2014 | 2001 Yamaha YZF-R1
Kohler pop up plug staying closed
The plug has a little hole in the end - that rocker-arm lever fits through the hole. If the plug gets turned 90 degrees to the side before installing the lever, the lever won't go through the holeand the popup won't pop up. Pull the lever back out, rotate the plug 90 degrees with your fingertips or thumb, and put it back in. It may take several tries.
Feb 05, 2014 | Kohler Plumbing
The right side parking lights stay on.
If you centralise the turn signal lever the park lights will go off. If you put the lever to the left the left park lights will stay on and If you put the lever to the right the right park lights will stay on (as long as the ignition is off).
This is designed so that you can leave half of the park lights on (to save power) for extended periods without flattening the battery so quickly. Selected Volkswagen/Audi models have had this handy feature since 1963
I understand that this change-over opeation of the turn signal lever is switched by the ignition switch.
Jan 22, 2014 | Miscellaneous
The lever on my rice steamer won't stay down any more, anything I can do?
Adjust ur THERMAL lever, underneath the cooker there is a SCREW w/ metal lever, adjust it till ther lever stays down!
Nov 05, 2010 | Aroma ARC7031G 6Cup Rice Cooker
The lever won't stay down
The lever will not stay down. Sometimes the lever will catch and other times it takes 6-8 times befroe it will stay down and toast the bread. Thanks....
Oct 16, 2010 | KitchenAid KTT570 4-Slice Toaster
Brake lever has slop in it brake light stays on when on accellin
there is a nyliner ( nylon bushing) around the pin on the pivot of the lever. start by replacing that- it is very inexpensive and easy to replace. while you have the lever off check the brake switch for proper function- it should switch on and off easily with just a simple push and release of a small screwdriver or punch.
Nov 20, 2009 | Harley Davidson FLTR Road Glide...
Turn Signal Lever 2004 Ford Focus LX
$35 sounds right for the lever. It definitely sounds like it's your lever acting up as the contact seems to be stuck
Oct 02, 2009 | 2004 Ford Focus
Lever on taoster will not stay down
I would just buy a new toaster...they are not that expensive. Check the intruction book first because maybe it's under warranty. Or if you bought it very recently, just take it back to the store. Most places will take it back even without a reciept if you tell them you just bought it and it's already broken.
Nov 22, 2008 | Kitchen Appliances - Others
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome... Logo
194 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
