Question about Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100)
Cant connect from laptop using internal wireless
I was using my pc s modem and all of asudden my laptop wont connect remotely hooked it up direct works perfect. just wont let me connect now
Have u tried a quick restore> that solves most issues that just started.? go to "start" "all programs" "acessories" "system tools" then clcik on system restore. select a restore point. select a date a day befor the problem started and click restore.*****NOTE..IF U DONE ANY UPDATES AFTER THE RESTORE TIME YOU SELECT..YOU MAY HAVE TO GO UPDATE AGAIN(NO BIGGGIE)...JSUT LETTING YOU KNOW.
Posted on Jan 07, 2009
I need connect a wirelees router a this modem,u help me plzzz
most wireless routers are setup for cable modems out of the box all you need to do is run an Ethernet cable from your modem to your wireless router. you can then access your wireless router by the ip address and a pc hooked you directly to the router.
Feb 28, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Can I connect a second computer (not a laptop) in my bedroom wirelessly to the 2wire modem that I have connected to my main PC?
Yes, you can. just make sure that the computer has a wireless capability, if not then you need to connect a wireless adapter so you could connect the computer to your 2wire router wirelessly. Another possible way to have it hooked up to your 2wire router is via Ethernet cable but depending on the distance you may need a longer cable.
Oct 10, 2010 | 2wire (1000-000057-000) Modem
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Cant use 2 laptops at same time
you need a router to connect 2 pc to one modem at the same time
Jun 15, 2009 | RCA DCW615R Wireless/Cable Modem
Cant access speedstream modem
Turns out that the modem stopped transmitting a wireless connection so that is why we couldnt get it working. After nearly putting a hammer through the laptops, we decided that we had better buy another modem. It now works better than ever :-) (phew)
Mar 25, 2009 | Efficient Networks SpeedStream 5100 Modem
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Need router or modem for ATT DSL 6.0
Your laptop has got a modem built in, but it is intended for dial up 56Kbps, not DSL. So they are both right. But if you want to use a DSL internet service you will need to buy either a DSL router or modem. You should not need to buy bothas the router will have the modem built in. Your ISP may have a prefered model and will probably sell you one at a fairly cheap price or you can get one from your local PC world. If you only have the one Laptop at home you can buy either the router or the modem. The modem will probably be cheaper. But for around $60 you can buy a router I prefer wireless. This will allow you around 4 connections and more importantly frees you up from having to be directly and closely connected and allows you to work in various places around the home without trailing cables everywhere. Your ISP will advise you on the settings you require. I advise you to enable all the security options on any wireless devices. I hope this was useful.
Carrie
Jul 21, 2008 | Computers & Internet
Adapters Compatible with the Westell E90-610014-06 Router?
run the modem to the router with Ethernet cable and then use one of the other Ethernet ports on the router and another Ethernet cable to connect desktop
Mar 04, 2008 | Westell Wirespeed LiteLine 6100...
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100) Logo
85 people viewed this question
Top Arris Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
