I HAVE A FRIGIDAIRE WASHER MODEL# GLWS1439FS. ITO ME IT SEEMS LOW. BUT THE FRIGIDAIRE TECH SAID THE WATER LEVEL SHOULD UP TO THE THIRD HOLE ON THE TUB, WHICH IT IS. IS THERE ANYWAY I CAN ADJUST THE HEIGHT OF THE WATER IN THE TUB?
You cant the water is meter though a pressure switch,,,but heres a trick but you have to find your way from here,,,fill the tub first than push the clothe,,careful of overflow,,if you do it enough you will be a master,,,
I would check with the vendor that sold you the unit and see what they have to say or send an email to the Contact Us link on their website and ask. I am guessing no mention of the in your owners manual?
It's possible that your pressure switch is bad. For that model it's Frigidaire OEM Part #134762010. It's about $40 on line. This manufacturer-approved water level pressure switch (part number 134762010) is for washers.
Water level pressure switch 134762010 senses and controls the water level in the washer.
Unplug the washer and shut off the water supply before installing this part. Wear work gloves to protect your hands.
Hi, This d/w is designed to run with low water level. The noise you are hearing might be the wash motor. Do you know if this has the single or dual motor setup? The dual motor style are not the greatest. The wash motor is known to go bad. You can remove the housing below the spray arm and see if anything has lodge in the in impeller. Please let me know if I can assist you further.
This is the water saver feature and the only solution may be to put it on the maximum wash cycle to get clothes really clean. These washers normally get the clothes almost dry.
Your water level is adjusted automatically by the machine, you dont have any control over this. What yu need to see is to keep your wall faucet fully open before the wash, also check whether the pressure is good. It is normal that you see a low level thru your glass in machine............
sounds as if your drain hose is too low. you need to have the hose higher than the water level in the tub. if the hose is below the water level the water will just pour right out
