Question about Canon i850 InkJet Photo Printer
How to put a ink cartridge in a Canon i850?
I am borrowing it from a friend and need to know how to do this.
  • 1,602 Answers
LIFT THE FRONT COVER UP , GIVE THE PRINTER SOME TIME AND THE PRINT HEADS SHOULD GO TO THE CENTER OR RIGHT OR LEFT MARGIN PUSH IN AND DOWN.
----------------------VERY IMPOTANT-----------------------------
I THINK NEW CARTRADGES INSIDE THE PACKAGING HAS INSTALL INSTRUCTIONS INSIDE THE BOX WHEN YOU BUY IT FROM CANON INK CARTRADGE, OTHER BRANDS MAY DO THAT, IF NOT SURE OPEN BOX LOOK INSIDE AND SEE IF THERE IS INSTRUCTION ON HOW TO INSTALL NEW PRINT CARTRADGE
ROD
Posted on Feb 04, 2009
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
All of the sudden the color does not print properly on my canon I850 - its washed out and orangish
Check the color cartridges, especially the yellow. If the yellow looks llike orange or brown then the ink is contaminated. It happens when the printhead goes bad. A membrane between the colors breaks allowing the inks to contaminate each other.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
How to deep clean the canon i850 printer? I took the black ink cartridge out to replace. Bought a new one but did not put the cartridge in for 3 months. Stapl;es said I need to do a deep clean now. And...
It's simple. Just use rubbing alcohol on a qtip. If you really want to do a deep clean, you can get a cleaner/degreaser. Look at Active Components website. It's safe on all rubber and electronic components.
Sep 30, 2009 | Canon i850 InkJet Photo Printer
Printing, but not full words Canon i850
Sounds more like the actual print head has become dried out and simply needs to be cleaned. This is a common problem with Canon Bubble and Ink Jet printers.
You should be able to remove the cartridge and then the print head shuttle that moves across the page. Once you have it removed, you will need to get a couple of Q-tip swabs and some DENATURED ALCOHOL, NOT RUBBING ALCOHOL as the water in rubbing alcohol will damage the printer head. Wipe the face of the printer head GENTLY with a moistened swab, you should see the dried ink dissolve, do this a few times until you see no further ink on the swabs.
Allow it to dry for a few minutes and then reinstall it into the printer. You will need to run the alignment function of the printer to ensure that the print is aligned properly. That should do it.
Cheers,
Keith
Sep 19, 2009 | Canon i850 InkJet Photo Printer
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Replaced ink in canon i850 printer. Now it will not print
Hello.
First make sure you removed any protective tape or caps on the
ink cartridge.
If there is a contact surface on the cartridge make sure
there is no dirt or fingerprints on the contact surfaces.
You can download the user manual here.. CLICK HERE.
Have a nice day...
/Tech5508
Feb 13, 2009 | Canon i850 InkJet Photo Printer
Black doesn't print
THE CARTRIDGE MAYBE NO GOOD OUT OF THE BOX.
PRINTER NEED TO BE CLEANED
I DONT THINK ITS A DRIVER PROBLEM
BUT YOU WANT SOME OTHER OPTIONS TYPE IN THE ADDRESS BAR:
CANON 850i INKJET PHOTO PRINT WILL NOT PRINT BLACK INK
ROD
Jan 11, 2009 | Canon i850 InkJet Photo Printer
Canon pixma ip3000 won't print
Check usb cable if they are installed firmly and correctly. Check proper voltage input though designed as Autovolt system.
Try plugging the usb cable on another free usb port or you may try another computer to check if your printer works.
See if there are blinking lights and error codes. You can google for its error codes.
Check flex cable continuity, maybe some rodents have eaten it.
Remove ink cartridge, turn the power off and clean cartridge contacts including the holder contacts, turn it on and return cartridges. You may try borrowing a working ink cartridge of the same type from a friend.
Dec 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon i850 lid over ink cartridges will not close
It sounds like your print head may have dislodged and not be in the correct position, remove the ink cartridges and raise the gray locking handle completely, then lift out the print head and remove it completely ( its the tray inside the slider tray that has the nozzles for the ink tanks ) then reinstall, there should be a slight click when its in the correct postion, reinstall your ink tanks.
Feb 10, 2008 | Canon i850 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
old marine
old marine
