Question about Konica Minolta DiMAGE Z2 Digital Camera
Exposer dial hi. my cameras exposer dial isn't working. lcd screen says no images. I can get to menu and have reset defalts but nothin works. can you please help me for I have a family day at six flags on the 28. thanks craig...
    Genius:
  • 2,985 Answers
This is a majot failure I think Minolta are no more now taken over by Sony Check out a web site - Minolta or Sony But I think it may be 'New Camera Time.
Posted on May 28, 2007
HI I HAVE APANASONIC DMC-TZ15 CAMERA..... I HAVE AWHITE SCREEN WITH ALL THE MENU WORKING BUT I CANT SEE PICTURES OR TO SEE WHAT I M SHOOTING... IV REPLACED THE LCD BUT THE PROBLEM WOULDNT...
This is because your problem isnt the LCD screen viewer; if you take pics and transfer at pc... the same condition appears when you transfer this pics at PC ?
If yes, and the problem continue, could be the CCD image sensor go to bad; in both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Sony service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps
Sep 20, 2011 | Panasonic Lumix DMC-TZ15 Digital Camera
LCD is almost white , no picture seen, Video section is not responding
This may be due to the LCD Screen issue or the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD image sensor issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option works only if you're able to access the menu of the Camera, otherwise power reset the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
Jan 19, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Hi Expert: I erased the images on my Mom's SD and
hi terry. go through the menu on your camera and find the reset. push it. it will take you back to the factory settings and should solve your problem.
please rate my answer as very helpful. thanks
Feb 28, 2010 | Canon PowerShot SD110 / IXUS IIs Digital...
Lcd screen: lighter images flash from normal to
You are probably viewing the preview screen in "Highlight" mode. To fix this, use the dial button at the back of the D80 and click up (or down) to see another depiction of the preview screen. It will show you different options until you can see the normal picture without the flashing highlights. Hope this helps.
NOTE: Please rate our help to keep this free service online
Sep 18, 2009 | Nikon D80 Body Only Digital Camera
Display not on
The EVOLT E-500 does not have a live view LCD screen so you can see the image you wish to take a picture of. You must use the viewfinder to take images with this camera and only use the LCD to review the images.
As far as to reset the camera back to factory defaults, you need to turn the camera dial to P go to the Menu and on the camera 1 tab right arrow over and then arrow down to custom reset setting and then hit the right arrow highlight reset and press ok it will show reset yes or no highlight yes and press ok this will reset the camera back to its factory settings
Mar 02, 2009 | Olympus Camedia C-5050 Zoom Digital Camera
Lcd doesn't work
While in shooting mode, set dial to stitch and then press menu. That's the only time my screen works, and the only way I can make changes.
Dec 08, 2008 | Canon PowerShot A590 IS Digital Camera
Casio ex z60 was dropped, screen is intact no image from ccd
YOU STATE THAT THE CAMERA PLAYS BACK PREVIOUS IMAGES? ARE YOU STILL ABLE TO TAKE PICTURES? IF YOU ARE, MOST LIKELY THERE HAS BEEN SOME DAMAGE BETWEEN THE IMAGE PROCESSOR AND THE LCD. THE FACT THAT THE MENU AND OTHER IMAGES STILL WORK MEANS THE LCD IS OK, SO YOU HAVE A CHOICE TO HAVE THE CAMERA REPAIRED TO CORRECT THE DAMAGE FROM THE IMAGE PROCESSOR TO THE LCD, BUT I BELIEVE THE REPAIR COST WILL BE MORE THAN THE COST OF THE CAMERA. I FOUND THE CAMERA ON EBAY FOR A STARTING BID OF $9.99. SORRY, BUT I JUST WANT YOU TO HAVE ALL THE INFORMATION. IF YOU NEED MORE HELP, REPLY TO ARCLIGHT1217. IF THIS HAS BEEN HELPFUL, PLEASE RATE, THANKS!
Nov 30, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Blank image when you turn on
I have same problem and just tried the "reset all" function in the menu. Then I turned off the canera and when I turned it back on the screen worked. I hope this works for others!
Apr 20, 2008 | Canon PowerShot A560 Digital Camera
Image quality
Hello there,
If you are correctly metering the exposure of your photos, and you suspect it may be the camera, try resetting the camera to its default settings using the menu. Clearing all the custom functions as well can sometimes help. I have seen some cameras get "stuck" into a weird shooting mode. Also, don't always trust your LCD. It is only there for reference, but is almost never a true representation of what you're going to get.
Hope this helps!
Apr 10, 2008 | Canon EOS-20D Digital Camera
Konica Minolta DiMAGE Z2 Digital Camera Logo
52 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
