Question about Philips ProScreen 4750 Impact Multimedia Projector
Color bars on both sides of picture
I actually have a Phillips Fellini 100. The problem started small on the right side of the picture, with a couple of small color bars visible in the picture. Now, this has progressed from both sides to virtually the entire screen. No idea where to begin to try to fix, or even if its worth fixing. Any ideas what the problem might be?
  • omalny Dec 08, 2008
    i have the same problem, and cant seem to fix it.
    need help!! please....
    Problem Solver:
  • 5 Answers
I've got a similar issue with one here. Problem appears to be a defective LCD,in the blue position, as swapping it with the one for green (the middle one) resulted in green bars instead of blue ones.
The good news: the LCD panel is easy to remove.
The bad news: the LCD panel is a NIGHTMARE to re-align when you refit it. I now can't get the green panel to line up properly, and of course the blue one's still faulty!
Posted on Aug 27, 2010
  • mspritch Aug 27, 2010
    The panels can't be aligned with the power on, as there's a PCB in the way. You've got to switch off the projector, unplug 7 ribbons, remove two PCBs and a baseplate, adjust the LCD panel position, refit the PCBs and ribbons, switch back on and see if it's any better. Presumably at the factory it's done using a test jig before the PCBs get fitted. Looking at the results on Google the 4750 has a tendency to eat these panels, a shame really.
    Problem Solver:
  • 14 Answers
The Problem seems to be in the RGB Panels.
Posted on Jun 04, 2007
Garmin Nuvii 55 LM battery icon color meaning
There are usually 4 side by side green bars if the battery is fully charged. You can think of each bar as 25% power, so (4) bars is 100%, (3) bars is 75%, (2) bars is 50% and (1) bar is 25%.
Feb 07, 2016 | Garmin nuvi 55LM 5" GPS with Lifetime Map...
My Phillips 42PFL7704D 42" LCD
As long as you have a good signal going to the set, absolutely return the set, especially if it does the same thing when hooked up to another source like VCR or DVD.
Jan 29, 2011 | Televison & Video
Picture freezes
a freezing picture is normaly due to bad input signal have your imp input signal checked
Oct 17, 2010 | Televison & Video
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Small bars across picture with no color
I have exactly the same problem and a Dell tech just recommended I replace the drum cartridge - $170.
Nov 07, 2009 | Dell 3000cn Laser Printer
How do I change the color wheel on my samsung HL-P5663W. I have already removed the lamp and loosened screws for the lamp housing. Doesn't seem to want to come apart. Am I on the right track?
5
6
7
8
Jul 10, 2009 | Samsung DLP HL-P5663W 56" TV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
I have a 2000 monte carlo with bi level a/c and drivers side is warm and pass side is cool what is the problem? thanks rick
Your blend door actuator (also called air temperature actuator) motor is bad. It's pretty common. The bad part is located under the dash on the driver's side, toward the center of the dash It is mounted on some AC ducting, with the top of the unit facing toward the driver's door.
Here's a forum thread discussing this issue (not monte carlo specific, but the pics of the part and the general location of said part is nearly identical. They take out a passenger side actuator motor in the thread. Driver's side is similar):
http://www.w-body.com/forum/index.php/topic,41201.0.html
For a temporary fix if you're slightly inclined to working on cars, get under the dash and remove the plastic covers hiding the wiring in the driver's foot well (a couple push tabs and a couple phillips screws is all that holds it up). Locate the driver's side actuator motor (it's partially hidden by some wiring, you'll have to reach up there toward the center of the dash to find it), remove the unit (2 gold colored phillips screws and a black connector, a #2 phillips bit in a quarter inch socket applied to a small quarter inch drive ratchet works well here), and then manually flip the blend door to the "cold" side (there will be a little knob sticking out of the AC ducting that you'll see once you take off the actuator motor. Just grab that knob as gently twist left or right to make the air temp hot/cold).
Here is a cheap place to get a replacement:
http://www.rockauto.com/catalog/raframecatalog.php?carcode=1358074&parttype=10721
GM wants $100 for the same part, not including the labor to install it (probably $45 to $90 for labor)
Good luck.
Aug 11, 2008 | Chevrolet Monte Carlo Cars & Trucks
Picture but no voice only music
the sound comes out but no surround sound it doesn't have the echo in the background
Aug 10, 2008 | Protron PHT-300X System
Phillips plasma 50pf7320
I have a 50 inch phillips plasma and the pixtals are taking over and color is dark the amblight is very dim,
Jun 25, 2008 | Televison & Video
Philips ProScreen 4750 Impact Multimedia Projector Logo
271 people viewed this question
Top Philips Office Equipment & Supplies Experts
Damen Wong
Damen Wong
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
