2004 Jaguar X-Type Logo
Jennifer Posted on Jul 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 jag xj8 low oil smoking when accelerate flapping noise
I have no codes. I changed the oil 2000 miles ago my husband used 50/50 I bought 10 30, We replaced a coil and put new spark plugs in. I have been hearing a flapping noise on the underody when I accelerate. My oil is running low and I have noticed the last few days when I accelerate there is a cloud of solid white smoke that stinks. I drive about 100 miles a day and need help with this issue. Thank you for your time.
Frank Magliocca
Level 3:
Genius:
  • Jaguar Master 1,461 Answers
  • Posted on Jul 15, 2017
Frank Magliocca
Jaguar Master
Level 3:
Genius:
Answers
1461
Questions
Helped
334198
Points
4325
Ck your coolant for a mixture of oil & coolant & any coolant in your oil. Sounds like a faulty head gasket or bad valve. where any of the plugs wet with oil or coolant? If so head gasket or valves. good luck
5 Related Answers
Anonymous
  • Posted on Aug 01, 2008
SOURCE: black smoke from exhaust
This is almost certainly a split hose - mine was the large hose coming out of the bottom of the EGR valve.
Speaking to a parts guy at my local Jaguar dealer, he said that the new part is uprated as Jaguar are aware that this is a problem.
The split allows more air in and results in the ECU changing the mixture and over fuelling - Black smoke is an indication of un-burnt Diesel. As well as the black smoke you may also notice a whistle/whine or sucking noise when you accelerate and a lack of power / lumpiness at around 2000rpm.
Hope that helps!
Graham
InMrFixIt
Rian Peters
  • 121 Answers
  • Posted on Aug 09, 2008
SOURCE: thick blue smoke. no oil
Hi! Chris, There are many causes of oil burning or exhaust smoke. There are three different causes of normal oil burning, 1; worn valve guides (smoking during deceleration), 2; worn cylinders and piston rings (smoking during acceleration), 3; split or worn out valve seal, or damaged intake manifold gasket (smoking all the time). Of course there are several variables in this equation. Sometimes coolant can also get into a cylinder and cause a blueish smoke. If you remove the spark plugs and use a pressure pump on the coolant system (radiator), coolant should leak into the intake manifold or cylinder. Coolant leaking into the intake manifold will leak into several cylinder through the valves. So, what year and how many miles are on the Jaguar?
Anonymous
  • 3 Answers
  • Posted on Mar 25, 2009
SOURCE: How do I change the coils on a 2000 Jaguar S-type 4.0.
2000-2002 S-Types are horrible for this problem. Especially around 80,000 miles or more.
You are feeling a misfire(s). If no check engine light, then the computer can't determine exactly which cylinder is misfiring. Yes the coils are under the black covers on top of the cam(valve) covers. One per clyinder. I would recommend replacing all eight as the new coils are a newer design and if you just replace one now you will be replacing them one by one very soon. Make sure the tech inspects the cam(valve)cover seals for leaking, as they are bad to leak into the spark plug wells and cause same problem. Also change spark plugs as well at this time. Good luck!
DFARLEY
  • 116 Answers
  • Posted on May 20, 2009
SOURCE: P0420 Error code, I had the sparks plugs replaced in dec...now one is misfiring again.
i dont know if this 402 code is a miss code on a jag but usually miss codes are p0300 codes. if you are hearing a ticking and you own a spray bottle, an old mechanics trick is to mist water on the plug wires while the engine is running preferrably in the dark.
Anonymous
  • 1124 Answers
  • Posted on Aug 06, 2009
SOURCE: Acceleration slow or choppy
A tune up is a good idea.. Also depends when the last tune up was..
And yes - spark plugs are included in a tune up..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Testimonial: "Got spark plugs changed and hesitation has stopped. Thank you."
1helpful
2answers
2000 Jaguar xj8 turn over won't start stability control fail light on.
the stab light comes on if the battery is low because you are cranking the engine your aj26 v8 engine may have a common problem for cars up to that model/year with worn nicosil coated bores ie. low compression check the vin no. at your jag dealer you can get it started by removing the spark plugs and putting a egg cup of engine oil in to each of the cylinders the first thing to do is to check for fault codes using a obd code reader for a clue followed by a compression test
1helpful
2answers
BLUE SMOKE FROM AUDI RS6 ON DE ACCELERATION AND START UP THINK OIL STEM SEALS ARE LETTING OIL THROUGH. CAR RUNS FINE I THINK, AND EXCESSIVE BUILD UP OF OIL IN DRIVER SIDE TURBO PIPE, 62000 MILES WITH A...
General rules of thumb: Low speed engine on acceleration with smoke in the exhaust plume = worn piston rings High speed engine accelerating (spooled up turbo) with smoke = oil form turbo bearing and/or piston rings Engine on over run (coasting down, foot off the gas) with smoke = oil from valve guides. VW/Audi make good engines with tight tolerances so none of the above should apply at 62K miles; just make sure that the oil (the right oil) and oil filter are changed regularly.
13helpful
6answers
Jag X TYPE Diesel Black smoke coming from exhaust on acceleration
i had this problem and thought the fuel filter oil filter needed replacing so i have just had a service done but problem is still there but not as bad. been told it could be the AGR valve or a split pipe going to it which recuirculates unused fuel back to burn again. therefore unspent fuel is coming out of the exhaust causing the black smoke. i am still looking for the answer aswell, hope this helps.
1helpful
I have a clicking noise in my 1998 xj8 with 38,000 miles.i had the belt tensioner pulley idler and serpentine belt replaced.the noise occurs when the car is cold after running 1 minute i give it gas and...
Not too conversant with the jag engine, but the symptoms are identical to an engine with hydraulic lifters. An oil change of the correct viscosity, usually cures the problem instantly. Hope this helps.
Oil seems to disappear
Check if there smoke from the exhaust if its high then there is change oil getting burn in engine ...
Good luck..
1helpful
3answers
OIL ISSUE
I have a 94 4.0L and I use 10W-40 in the winter and 20W-50 in the summer. It keeps the pressure up and it doesn't smoke when I start it because of the valve seals. It takes 8 quarts everytime including the filter. 2 gallon jugs. I change it about every 4,000 miles.
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
