Question about Hunter 52" Ceiling Fan With Light And Remote Control
Hunter Remote 85094-1 doesn't work after I dropped it
I bumped it off the holder on the wall and now it lights up but doesn't activate the fan or lights. We checked the battery and it's still good. Any suggestions?
Thank you.
    New Friend:
OK...my Hunter remote stopped working so I checked the battery and remote as described above. The infrared light came on so I assumed it was the fan, power switch, or out of sync fan/remote. My wife insisted it was the battery so to prove her wrong I swapped the battery with another remote I have. The remote worked with the other battery.The other fan failed to operate. If battery is low the infrared will come on but there may not be enough juice to power the transmitter signal. I had to eat crow and buy a new battery. Good luck.
Posted on Aug 12, 2016
  • 61 Answers
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
otherwise, the problem with the Remote sensor or related components of the device
Posted on Mar 11, 2009
5 Suggested Answers
SOURCE: Remote control ceiling fan
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
Posted on Apr 12, 2008
SOURCE: Hunter Fan has stopped accepting remote control signals
The receiver is at the bottom of your fan (just above any light kits), inside a round case about 4 inches tall. You will have to take 3-4 screws out and inside you will see the receiver. It should have an electrical connector going to it with dip switch as well. It will pull right out of the case.
By the way, I am having the same problem and am trying to get ahold of Hunter for a new receiver.
Posted on Jun 19, 2008
  • 5 Answers
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
if the battery's are good then you broke it and you have to order a new one which you can do by calling the place that you got the fan from tell them what kind of fan you have and let them know that you nead a new remote and they will be able to help you do that.
Posted on Aug 13, 2009
  • 5 Answers
SOURCE: Hunter ceiling fan w/ remote won't work
You need to change the receiver inside the fan. It is located in the top canopy of the fan. you don't have to buy a new remote just the receiver to save money and match the dip switches to the remote.
Posted on Jun 09, 2010
I have a hunter remote control with a part # 85094-01 and a FCC ID: IN2TX13 and the remote will not turn the lights on but does work for the fan. It is a 12v battery and we have replaced it
  • Disconnect power at the source
  • Remove remote battery
  • Press all buttons to eliminate possibility one is stuck
  • Reinstall battery
  • Reconnect power at source
If this procedure does not work, the remote or the receiver in the canopy may be defective.
Jul 30, 2016 | Hunter Dryers
How to set dip switches in hunter ceiling fan remote 85094-02
Fan switches and remote switches must "mirror" each other, otherwise fan will not operate properly or if at all. For instance: if switch 1 in remote is set "on", then switch 1 in fan must be set to "on".
Jun 25, 2015 | Hunter Dryers
Call 1-888-830-1326. Must have model number which is a 5 digit number starting with a 2 found on the top of the motor housing.
May 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Code for remote control
thats right !! the combination is the same as the PINS located at the top of the fan, good luck , AJ
Nov 28, 2009 | Hunter (25417) Ceiling Fan
Hunter Fan - Remote
Most likely the fan turns on with a wall switch and then as long as the power is there [ wall switch left in on position], the remote works
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Lights are on all the time, fan doesnt work, remote does not work
I have changed the remotes on 5 Hunter fans in the last 3 months. They have a problem with how some of them mount, that makes them drop down and vibrate loose. If you do not have a wall switch for it, you may want to go to pull chains, or just replace the remote. It is NOT the controller you hold in your hand, but the part in the fan. (never the easy way right?) The remote is not hard to change, but you DO have to let the fan hang from the holder on the ceiling bracket, It gets too heavy to hold while you change the remote.
All but one of the remotes I have changed, came from a mass market type of builder/handyman store, and they have just replaced the part at no charge.
Dec 21, 2008 | Hunter 52" Ceiling Fan With Light And...
Remote lights/but fan doesn't work
Don't have a solution to this problem, but I'm having a similar problem. The remote works for the fan but the other day we had a light bulb burn out and ever since then the switch on the remote for the light will not work, but the fan works just fine. If anyone has a solution please post it or email me at dustinbrown_18@hotmail.com Thanks
Feb 24, 2008 | Hunter 20531 Vista Brushed Nickel Ceiling...
Dryers Logo
1,291 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
