Question about GE 24 in. GSD2230Z Built-in Dishwasher
We have a GE Dishwasher Model # GSD 2000 Z02AD - water leaks
Because we hadn't used the dishwasher for awhile, the vanes were stuck and we loosened those and the dishwasher turned on. We were letting it run through a cycle with no dishes in the dishwasher and we noticed that water was leaking around the areas where the vanes are. What might be causing this?
    Novelist:
  • 166 Answers
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
What causes the water to stay running on a ge gsd series dishwasher?
The float is stuck it may need to be replace it is located on the front left side of the dishwasher
Apr 08, 2013 | GE 24 in. GSD1000G Built-in Dishwasher
I have standing water in bottom of GE GSD 666 dishwasher. I pressume I need to clean screen/filter? How?
I have the same problem, same model GSD660G0322. Have an inch or two of standing water. When I run the drain pump in Service mode, it successfully clears the water. How do I access the filter to clean?
Oct 22, 2011 | Dishwashers
I have a GE GSD 5130 Dishwasher that leaks about 12 oz of water when it is pumping out the wash water and the rinse water. Its fine during the wash and filling cycle. Is it a seal problem?
This is more likely the hose connection at the drain pump or the pump housing is leaking. You will need to remove the toe kick, place unit into a drain cycle and inspect for a leak. Here is a couple links that should help.
http://appliancehelponline.com/dishdraincircpumpvideo.html
http://appliancehelponline.com/dishwasherdrainpump.html
Jul 15, 2010 | GE GSD5130 Dishwasher
GE Profile Dishwasher Mod. #GSD 4430
I have the same problem right now. What is the casue?
Oct 19, 2008 | Dishwashers
Ge dishwasher problem
Soap is not disolving because either your water temp. is too low (adjust at water heater).Or your sprayer arms are clogged up.(remove any particals that can be trapped in the holes on your sprayer) THATS IT !! PLEASE LEAVE A RATING !!!!!
Jun 08, 2008 | GE 24 in. GSD4000J Built-in Dishwasher
Dishwasher Does Not Cycle
IA, these GE pumps have a habit of sticking if the unit hasn't been run for a while. First you want to verify that the motor is in fact getting power, this will eliminate the timer. You can use a meter on the quik connect from the motor while in the wash cycle. If the motor is getting power, see if the pump is stuck by turning the motor vanes (Do this with the power off). If it's hard to turn and then frees up than this was more than likley your problem. You remove the bottom toe panel and will be able to check this out without removing the dishwasher. Catriver..post back
Dec 29, 2006 | GE 24 in. GSD2230Z Built-in Dishwasher
Losing water pressure in pump?
Shellybabe, these GE dishwasher pumps have a habit of sticking when not in use for a while. It sounds like you have been washing but not good. If you remove the toe panel (lower) you will see the pump motor in the center. If the vanes in the back center of the motor turn freely, your pump is not stuck. If they wont turn, put pressure on them until the pump frees up. You also want to make sure that the fill valve is letting in enough water. The water should be just below the heating element after the initial fill. If you are not sure try adding 2 addition quarts of water to the machine after the initial fill and see if the circulation is better. Remember to unplug or kill the power to the dishwasher when checking the motor vanes...Catriver..post back.
Oct 31, 2006 | GE 25 in. GSC3200Z Free-standing...
Dishwashers Logo
721 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
