Anytime I shutdown/logoff, I cant restart Vista unless I do a system restore.
It continually tries to do a Windows repair with no fix/ until I do the restore.
I can't do any updates on Vista or apple products because it will do a shutdownleading to the same problem.
Any Ideas?
To activate the administrator account in Vista, follow these instructions:
Replace password with the actual password string that you have chosen. Press Enter when done.
If not success message is returned, repeat the process again.
If the problem is caused by something that is installed under your normal administrative profile,You will be able to fix it under the Administrator account.(This is a hidden account in vista),The Administrator with the capitol A give you total Administrative rights.Which will allow you to fix more than the normal account.
windows cant find the operating system
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Hi Rockitman, why would I try this fix?
to see what errors are generated?
i ran AVG antivirus, didnt help or find problem
Have you run anit-virus.
Does it mention anything about finding new devices or hardware?
