Question about Arris DCT6200 DTV Receiver
6214...Hunt and Fr1
I have a DCT 6214 as soon as I plug the unit on, the unit turns on with a code of Eb09 then it goes cucles through hunt and Fr 1 -10. It repeats it self then it reminds blinking with hunt Fr 1. I am not able to power on or off the unit and the unit not seem to take and commands from either the remote or directly the unit...PLEASE HELP
  • Anonymous Feb 02, 2009
    That's happening to me too. It's getting super annoying.
Codes for universal remote RCR4358 to work with Dolby Digital HDTV
all universal remotes have a code hunt . see the manual.
it will be likely the one that turns the unit off/on
1 Hold down the television and power button till it turns red
2. Then press play once the light will blink once it stops if the t.v. has not turned on press again, continue until the t.v. turns on.
3. Press reverse until t.v. turns off
4. Hold down stop till light goes off
May 10, 2015 | Universal Televison & Video
Overdrive is kicking in to soon
it can, in fact newer cars do it even more.. .saves fuel....
if fact new cars have fast 1 to 4 gear jump, (no load) MPG feature.
what is it doing and when, and under what loads?????
do you mean downshifting too soon?
OD is top gear. and TCC is torque converter lockup
down shifting happens 3 ways
1: you do it. shifter.
2: low vacuum this is the Load sense, hills cause low vacuum and it down shifts.
3: TV, this is throttle valve , sensed, you stab throttle to pass.
aka; detent, TV. passing gear.
on some cars there is an OD switch to cut out OD, say pulling trailer
pulling any heavy load, may case the OD to hunt, or the TCC to hunt
and is a real pain....
btw the FSM covers all 100 A/T issues, up shifts, down, slips. flare, early ,late. ... its complex device, tend to not own them.
Dec 31, 2013 | 1987 Acura Integra
Check engine soon light flashes
IT IS MISS FIRING YOU ARE CORRECT AND IF YOU GO TO ADVANCE, PEPBOYS. THEY WILL FIND A CODE FOR A MISSFIRE .THEN YOU START TO HUNT IT DOWN AND THINK, WHEN WAS THE LAST TUNE UP LOW FUEL PRESSURE OR BURNED VALVE . MAKE A LIST AND START THE HUNT
Nov 25, 2013 | 2000 Nissan Xterra
Looking for postal code for Hunt Club Drive, London, Ontario
The postal code for 154 Hunt Club Drive is N6H 3Y8, 1 Hunt Club Drive is N6H 3Y8, 240 Hunt Club Drive is N6H 4J6 - depending on the address the postal code changes. Via maps.google.com. Alex
May 30, 2011 | Computers & Internet
Oven will not turn on f-1 code
Your oven control has declared it is faulty. You should replace it. But try this first. Remove that molex plug and hunt for corrosion before buying anything. Just cover the bases right?
Dec 21, 2010 | Maytag PGR5710 Performa Gas Kitchen Range
I set up Hunt Group 1 (290) on a CICS, w/6.1 softewre with A Call Pilot 100 and assigned & initialized mailboxes for each Hunt Group member (222, 223 & 224) to FNA to Voicemail (227) after 4 rings....
Without having the programming manual on hand for this switch I have to generalize from other switches. Double check your auto forward settings within your hunt groups. It sounds like you have auto forward set wrong. If you have the voice mail set to engage on the 4th ring try changing that to engage on the 6th ring with the forward within a hunt group to forward to next available on the 3rd ring, see if that helps.
Aug 05, 2010 | NorStar Cics 6.1 & Call Pilot 100...
Game won't play on my new computer.
Are you sure the game is designed for Windows version earlier than XP? You can try compatibility mode.
  1. Right-click executable file of the game.
  2. Click Properties.
  3. Pick Compatibility tab.
  4. Check Run this program in compatibility mode for:.
  5. Pick version of Windows that the game was designed to work on.
  6. Click OK.
  7. Run the game.
Jan 16, 2009 | EA Sports Deer Hunt Challenge for Windows
PICK UP GROUPS AND HUNT GROUPS
You will need to talk to the phone administrator. It needs to be set up in system admin.
Nov 08, 2007 | Avaya Definity 6408D Corded Phone
Programming the DSS/BLF
Need to login in system and program buttons from there.
Nov 07, 2007 | Inter-Tel Axxess Phone 5504400
Arris DCT6200 DTV Receiver Logo
484 people viewed this question
Top Arris Televison & Video Experts
Electro Med Services...
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
