Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Water running from under the refrigerator
I've had my refrigerator for about 7 years and now water is running from under it. Everything else runs fine. It still gets cold and the freezer works well. How can I fix this?
  • williams604 Jan 06, 2009
    My fridge is a normal one. It is a gss25lg side by side. It is hooked to water because it has an ice maker.
Experts say that there may come a time in a fridge's life where you have to open the back panel and clean the condensation coils. When they go in cooling mode, you get frost on the outside of the firdge (on the coils) because of the dirt. When the fridge goes off cooling the frost melts and of course, comes out under the fridge. Still is your fridgea normal one, or one that is connected to a water pipe?
Posted on Jan 06, 2009
If your refrigerator is of the type which has automatic defrost, the problem is in the pan under the fridge.
The compressor area undr the fridge is full of lint and air is not flowing to the point to allow evaporation from the pan or the pan has rusted and leaks. Remove the pan and check it out and while you are there, clean the fins of the coil under the fridge.
2 Suggested Answers
Crew Dawg
  • 275 Answers
SOURCE: I opened freezer on my
It could need refrigerant...I'd try to possibly get a quote on that.
BUT FIRST,
I'd ensure the coils were cleaned of all dust and dirt...either by vacuum or blow it with compressed air.
I'd also check to make sure the light goes out when the door is closed. Sounds crazy but I had a bad switch once that allowed the bulb to stay on constantly...makes everything warm.
Posted on Jul 17, 2011
Stopped making ice
I hate to say it.....heres a review "
This is the worst refrigerator I've ever purchased -- and it's all because of the icemaker. It's been repaired 7 times in the last 2 years thanks to having purchased an extended warranty. Predictably every 6 months, the icemaker stops functioning. There's a piece that jams. The repairmen are at a loss. I give up -- this weekend, I'm headed to my appliance shop and buying something different. Don't waste your money on this piece of junk...."
I think there is a genetic problem. Are you under warranty?
Mar 19, 2014 | Maytag MFI2266AES Stainless Steel Bottom...
Tip
How to fix a leak inside a refrigerator
Turn off the refrigerator. Remove the rear panel and floor cover from the freezer. You will see a lot of ice covering everything. Remove/thaw this ice.
In the back of the freezer, under the coils is a drain. When the defroster runs and melts the ice on the coils, the water is supposed to run down the drain to a pan where it is evaporated by a fan under the refrigerator. Often, this drain freezes shut. Then, the water has no place to go but though the vent into the refrigerator.
Melt the ice in this drain with a hair dryer or small quantities of hot water. You will know the drain is clear when the water level suddenly drops. Finish drying everything in the freezer and replace the panels.
Now, you will no longer have water dripping inside your refrigerator.
on Feb 06, 2010 | Refrigerators
I have a top freezer Hotpoint refrigerator at a lake home. It's about 6 years old. I've been getting water in the refrigerator compartment. I've tried to clear the hose on the back by...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 03, 2011 | Hotpoint Refrigerators
Hello, I've been using the "Whirlpool 25.1 cu.
Maybe trash has made its way to valve and it is partially stuck open. Or maybe all air is not out of line. Run water through dispenser until it stops splurting air and there is a steady stream of water.
Sep 23, 2017 | Whirlpool Refrigerators
The unit runs but does not collect water...it just runs. I've left it on for several hours. In the meantime, my basement is very moist with a lot of humidity from all the rain we've had. Even my...
the units low on refrigerant or freon,its normal for these to lose their charge after 2-3 years of use,i repaired a lot of these over the years,a couple of B.P.V.'s and about 9 ozs. of whatever type of refrigerant or freon and they will go another couple of years, all for about $50.00
Jun 01, 2011 | Kenmore 54501 Dehumidifier
Water is pooling under vegetable bin at bottom of refrigeraqtor. Seems water is coming from insude refrigerator under freezer shoot. Placer plastic cup under it and it has collected water that froze....
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 19, 2010 | Whirlpool Refrigerators
My refrigerator is 9 years old and yesterday it started thawing everything out it is running but not keeping anything cold
If the compressor is running and the fan under the unit I am afraid you need to buy a new fridge. This normally means its low on freon you could have a repairman add some but at 9 years old I would recommend a replacement. But make sure the compressor is running and not just the fan the compressor will hum.
Aug 16, 2010 | Whirlpool Refrigerators
Same problem.... almost eight years July 7, 2009
Dirty condenser (the coil under the unit or behind it). Vacuum it out. Could possibly be the thermostat going bad or the compressor. If it has an ice machine, it may be bad. Most fridges run everything through the ice machine.
Try cleaning it inside and out and make sure the inside coil is not frosted over. That could be a symptom of another problem.
Jul 08, 2009 | Maytag MSD2756GES Side by Side...
My refregerator is sid by sid, not making ice and is not cooling
if the fan motors and everything is else is running proprerly, i wouldnt be suprised if you needed to have some freon added to the system.
Apr 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Water continuously running to fridge, overflowing?
Hi, if the only way you could stop the water was to turn it off at the water source, you need to change the water inlet valve. Make sure you check the water fill line for any leaks before you change the valve.
If I canassist you in getting the vavle, please let me know.
Thanks
Vic
Feb 18, 2009 | Whirlpool ET0WSRXML Top Freezer...
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
