Question about Cuisinart Thermal DGB-600 Grinder
Nothing works, only flashing program light and time
The program light and time flashes but nothing else will work, I tried to push, push hold the other buttons and nothing happens. I just keep getting the flashing program light and flashing time. I even unplugged the unit over night with no success
  • 3 more comments
  • coffeepot Nov 24, 2007
    yes, I have this same problem. Has ANY solution been offered? I have taken the same steps as the one posted and have not been able to resolve this issue. What solutions have you offered?
  • bobnblues Feb 20, 2008
    Only the program light is flashing, and the time is flashing 12:00 pm
  • Anonymous Mar 10, 2008
    as of 4:00 a.m. this morning our coffee maker is doing the same thing. if anybody has any ideas on how to fix this PLEASE let us know asap.
  • lynngold Aug 06, 2008
    coffeemaker beeps and doesn't start
  • Anonymous May 08, 2009
    same exact problem..this is irritiating
Listen to this! we called Cuisinart at 1-800-726-0190 and they are going to sihp us a replacement coffee maker and all they are going to charge us it the price of shipping. good news since spending so much for a product. great customer service.
Posted on Mar 11, 2008
  • Thomas Brown
    Thomas Brown Dec 04, 2013
    This is a 5 year old solution, but it still works! Customer service will replace non-functioning unit with no proof of purchase if within three years of manufacture. Just call this number, give them the model # and serial # from the bottom of the unit. They will send new unit to you once they receive old one. If outside 3 years, you will need proof of purchase.
Uniden 796d was trying to program trunk line pushed mutltablr buttons now wont turn on
First try doing a reset first. If uou hold down 2,4,an 9 while turning it on it should reset. If not use 2 an 4. This works many times. Also have you tried connecting to the computer with it? I would try the factory rest first.
Jan 18, 2015 | Uniden Radio Communications
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
Garage door programming doesn't work
try resetting the homelink system by holding down the first and last buttons at the same time until the light flashes rapidly on your visor. this could take up to a min. then at the same time press whichever button you want to program on the visor and the garage door remote button at the same time until the light on the visor flashes rapidly.that could take up to a min. after that is complete you need to go and push the learn code button on the back of the openers unit, then go and push and hold the button on the visor you just programmed until you hear a click or you see the light flash on your opener unit. after that try using your homelink. note there is about a 3 second delay when using homelink. you need to push and hold the button until you see the door operate.
Sep 10, 2012 | 2007 Mercury Grand Marquis LS
The clean button blinks, yet it won't start?
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes. I had the problem for several days and could not use the dishwasher not mater what tried until I did what I described above. Now I have to see how long it lasts.
Jul 24, 2012 | Kenmore 24 in. 15689 Built-in Dishwasher
Toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
Jun 18, 2012 | Toshiba Satellite Computers & Internet
Have a BA TVee 25 Soundbar. Only able to program Volume Up on my remote. Cannot program Volume Down or Mute. Nothing happens except to turn the Soundbar off and on. Don't tell me to follow...
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Jul 26, 2011 | Boston Acoustics TVee Model Two TV...
Wired unit asper instructions. try to program unit, starting with transmitter. cycled key as says ,then with in 15 seconds bushed progrm button twice holding in on 2nd time, parklights flash and led...
you need to push it 3 times and then hold, to program the unit for tach, voltage or timer. It will not work until you actually program the unit on HOW YOU WANT IT TO START.
Jan 30, 2011 | RS60 Stand Alone Remote Car Starter System...
Installed the prestige remote start(aps687n) on my 95 jeep grand cherokee but when i try to remote start my parking lights just flash 7 times and nothing happens. Any ideas???
Yes, the seven flashes mean that the tachometer setting has not been programmed. If you hooked up a tach wire (green with orange stripe) to an uncommon coil or injector wire, then you have to program tach: turn ignition on, press and release programming switch three (3) times. The parking lights will flash once to confirm. Turn ignition off. Press and hold programming switch. While holding the programming switch, start the vehicle. The parking lights will flash to confirm that the remote starter is getting a tach signal from the vehicle. Continue to hold the switch for approximately 15 seconds.The parking lights will continue to flash while holding the switch. Release the programming switch. The parking lights will come on solid for one second, then go off. The tach is not programmed. Turn ignition off. Test system.
Sep 19, 2010 | Prestige Remote Start
Ive just moved into a flat with a servis 7kg 1500AA washing machine and i have no instructions for it. when i press the on button the yellow light above another symbol flashes and nothing happens. ive...
Hi. Set the dial to reset (12 o-clock position) then push button second from right. Now set to program required and press button again. Should work now. Needs resetting every time, this is normal. Hope it works for you.
Sep 10, 2010 | Washing Machines
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Cuisinart Thermal DGB-600 Grinder Logo
453 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Norman Worley
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
