Question about Belkin Mini Wireless Optical Mouse F8E825-USB
Belkin travel mouse F5L017-USB not working don't have instructions, they were thrown away with the wrapping paper! please help
  • 2 more comments
  • Anonymous Jan 21, 2009
    Does not work-help
  • mouse5_5 Feb 01, 2009
    THIS MOUSE DOESN´T WORK
  • krishna_bed0 Apr 12, 2009
    can not sync the mouse at all
  • Anonymous Apr 30, 2009
    it worked for one hour, then stopped and can't get it to work again! Does anyone know how to fix it??
5 Suggested Answers
ramesh singh
  • 126 Answers
SOURCE: Belkin wireless travel mouse F5L017-USB
if the prob is within two weeks then do the system restore,take the computer to an earlier ti when the mouse was working fine...hope it will work...
Posted on Jan 27, 2009
1alexh
  • 484 Answers
SOURCE: Need directions to install
There may be a very small button, recessed on the bottom of the mouse, and one on the transceiver, which need to be pushed with the tip of a ballpoint pen. They cause the two devices to sync to each other and that makes the wireless mouse work right.
Also, be sure you have plugged the transceiver into the right socket on the back of the PC. Some require it be plugged into the keyboard socket, others into the mouse socket, and then of course, there are the ones that use a USB port. My Microsoft wireless mouse uses USB, and works like a charm.
Good luck.
a.
Posted on May 21, 2009
  • 92 Answers
SOURCE: Belkin wireless travel mouse not connecting to Mac
If you have a usb extension cable try plugging it in so you can place it on a firm surface when you press the sync buttons. Have heard of some issues with activating both mouse and fob buttons at once because of difficulty in reaching the fobs sync button.
Posted on Aug 13, 2009
  • 19 Answers
If you have a touch pad (which almost all laptops do, including MAC's), try disabling before you plug in the wireless mouse. You should be able to select the option to have it automatically disabling the touchpad everytime you plug in the wireless usb mouse.
SOURCE: how to change the batteries in a belkin travel
how to open a belkin travel mouse to change batteries
Posted on Dec 05, 2010
When i put the usb the pc could not feel it
Try the USB on another PC so as to confirm if there are errors, hardware,USB connector or driver issues . If the USB does not work then you have a faulty device for which much cannot be done.
If not you need to reinstall the OS and drivers on your PC if a restore does not help.
Jul 13, 2011 | Belkin F5L017 Mouse
I purchased the belkin wireless mouse, F5L017, it showed me suceffull instalation but no response from the device. Any idea?
If by successful installation you mean that you plugged in the USB dongle and it installed then I would suggest putting in the disc that came with your mouse and going through that installation process to make sure mouse is properly and full installed.
If that doesn't work then I would try to restart the whole computer with the USB dongle attached which will let the computer finish installing the USB driver that was installed when it was first plugged in
Feb 28, 2011 | Micro Innovations Wireless Optical Travel...
Mouse
check battery connection from mouse be sure lens is working and usb connection (receiver) detect in device manager.
Apr 12, 2010 | Belkin F5L017 Mouse
Can't get my mouse and usb to sync
There might be a button on the bottom of the mouse that syncs it to the port. Also there might be a button on the usb insert that has to be pressed also. Hard to tell without seeing it.
Hope it helps.
Nov 19, 2009 | Belkin F5L017 Mouse
How do I use the travel mouse? Belkin wireless travel mouse F5L017-USB. I dont know how to activate it.
there is a button on the mouse and on the dongle u got with it, plug it in install the drivers, make sure the batterys is charged, then after installpush the frequency button on both to activate
Oct 07, 2009 | Televison & Video
Aug 13, 2009 | Belkin F5L017 Mouse
Good luck.
a.
May 21, 2009 | Belkin F5L017 Mouse
Jan 27, 2009 | Micro Innovations Wireless Optical Travel...
Belkin Mini Wireless Optical Mouse F8E825-USB Logo
475 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
