Question about Cell Phones
My phone displays a white main screen
My phone has a blank white main screen and i don't know why the front screen still has everything on it but the main screen is white i have only had my phone for about a month and have not had a problem with it until now what should i do and how can i fix it? please help i just got my phone it has been 12 days since i had this phone but it got ran over and now the screen is white but everything else works please help me i love this phone
My mobile is a mobile phone watch and i bashed it or it went into the water what can i do help please
Posted on Mar 11, 2009
    Sergeant:
  • 290 Answers
If it was run over probably the LCD is damaged even if not visible take it to a repair center for that manufacturer
Posted on Jan 07, 2009
My LG phone screen will not react to touch
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Good luck.
Jan 12, 2012 | LG GT540 Cell Phone
My problem is my inside screen went blank white. About a week ago the inside screen started to do weird stuff like one day it had multi colored snow. The next it went blank. The next it looked like liquid...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Oct 05, 2010 | Motorola Mobility E815
Take care.
Blank screen
Good luck.
Jun 24, 2010 | Motorola Mobility RAZR V3
Sony erricson f305 mic problem and G502 blank display problem and k810i blank display problem show me the details with circuit pcb diagram and solve my problem.
first mobile was ok. problem was display white light. i changed the strip .now no white light and front keypad light .i changed the display,main strip also but of no use .pls suggest something
May 15, 2010 | Sony Ericsson F305 White +512MB Unlocked...
Display problem
try reformatting it.
May 05, 2009 | Sony Ericsson K750
Samsung G600 mobile phone blank screen
sgh d880 screen is totally blank & everything is ok widout screen. everything is ok when connected to tv output, the screen is displayed on tv bt it is white on phone plz solve my problem.
Apr 10, 2009 | Samsung SGH-G600 Cellular Phone
Blank or White screen on new Motorola Krzr k1 cell phone
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
My Solution: Heat it up by just sitting on it or holding it in your hands// Take the battery out and back in/ Try keeping the battery out of it for a full day
My Story :) My mom dropped the phone in the dishes because she was drunk haha, I quickly took out the battery, but when the next day came by I looked at the phone and saw the same problem everyone here has. I kept replacing the battery on the hope it would just magically fix itself. Now 2 days from when it dropped in water, I kept flipping it, replaced the battery again (just taking it out and back in) after I sat on it a while, possibly the heat somehow helped it to work again.. I'm amazed it works haha, it was in the water fully submerged for half a min when I had to snatch it out of the dishes But, it is most likely that I took the battery out, the battery is the thing that ruins electronics, just remember to take it out if you drop it in water. Good luck. If worst comes to worst and your going to buy a new phone, maybe try using a blow dryer on it for a little bit **or just do this in the first place**
Jun 28, 2007 | LG VX8300 Cellular Phone
Cell Phones Logo
1,098 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
