Question about Roper RGX4634KQ Gas Dryer
Dryer will not start
Had my sweater stuck in door.pulled on it and released it.but now the dryer dont start
  • 1,198 Answers
You may have damaged the door switch, or the tab that operates it.
Posted on May 09, 2009
My bosch maxx 7 sensitive dryer is not working - no lights are lit up, door is closed, filter is clean, container is empty, just beeps twice when i pusch start
Well I would recheck the water reservoir is fully inserted ....the door has no debris inside the lock....the bottom filter is cleaned not just the door filter.if this still not fixes then try a reset by switching off at socket then whilst holding start button without releasing for at least five seconds turn on power and listen for a click.sometimes a sensor is stuck and not relaying proper status.
Feb 22, 2015 | Bosch Dryers
Door switch needed
Oct 21, 2013 | Dryers
Opening the door after a wash
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
Press "start / pause" until the start / pause light flashes.
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped.
Mar 18, 2013 | Bosch Logixx WFT 2806 Front Load...
Bosch Dryer WTL 5410 UC do nothing after selecting a program and hitting the start button. The only thing that happens is that the Drying light lits and nothing else happens. I have tried to hit start...
Door switch may still be your problem. Mine showed lights as if working when closed but I decided to use a screwdriver and push in switch all the way in. It worked then without door closed. It will stay stuck until you pull it own a bit to release it. Give it a try. The door switch appears to have two switches in it requiring it to be all the way in.
Aug 12, 2011 | Bosch Axxis WTL 5400 Dryer
Hi, Model: Maytag DE8410 electric dryer The cycle completes and the buzzer sounds, but does it not stop until I pull the door open. I think I also got it to stop by rotating the cycle knob as well. I...
the timer might be bad and the part # for it is 306040
it is safe to clean it when it is not plug in , just be cearful not to move the wire from the place they in.
if it is not big problem dont replace the timer its 100$+ so live it till the unit die ... it is old unit any way...
Mar 27, 2011 | Dryers
How do I use the dryer rack?
The dryer rack is used for laying out clothing that you don't want to get tossed around. Example: Sweater or tennis shoes. It sits in a groove behind front door and sits in groove at back of tub.
Sep 27, 2010 | Samsung Dryers
My door latch will not lock in to place. It is below freezing and I dont know if the door is broke or the latch is just stuck
Likely it's just stuck. Spray it with wd 40 or other solvent and make sure the latch hook is open. If it's not, pull the door release handle (like you are opening the door) and gently pry the hook back to the open position.
Dec 10, 2009 | 2006 Jeep Wrangler
My dryer
Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Roper RGX4634KQ Gas Dryer Logo
55 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
