Question about Kenmore 44102 Front Load Washer
Washing machine will not start
I will be wahing a load and it is working fine and then the next time the washing machine will not even turn on?
  • 15,935 Answers
Check/replace the main ECU board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Mar 04, 2011 | Washing Machines
Whirlpool AWM1019 wahing machine - what does AH code mean on display. Will do all the right things but wont move on ie wash and drain but then wont rinse. On start of any programme starts to fill then AH...
Hi! I checked both the inlet pipe and the rinse drain pipe. Both are fine. What next. The machine gets to 26 and then starts beeping. It is driving me absolutely crazy!!
Jan 23, 2011 | Whirlpool Washing Machines
Hi, good evening. I have a zanussi iz12 washing machine that stops during rinse node and gives e20 fault (wont drain). I checked the pump - working fine. I've found that if i blow into the waste pipe the...
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Jan 11, 2010 | Zanussi IZ12 Front Load Washer
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Water supply
yes it is normal. It fills up during the washing proces
I had the same thought at first but it truns out ok.
Jun 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Wahing Machine Motor Overheating
...same problem here. any answers?
May 02, 2008 | Washing Machines
Kitchenaid top load wahing machine # YKAWE870BW1
You need to replace little gears called agitator dogs. Once agitator is removed pull top half of it off. Exposes the dog carrier.
Nov 28, 2007 | Whirlpool LSB6200KQ Top Load Washer
Detergent & Conditioner Drawer
Perhaps it needs to be thoroughly cleaned out first - sometimes the gloopy mess collects and blocks the outlet hole.
Oct 30, 2007 | Neff W4380X1 Front Load Washer
No power to washing machine but fuse is ok...
could be 2 things 1)try closing the door and banging the machine on the front next to where your door catch goes into the washer if it starts could have a lose wire or be faulty 2)if no1 doesnt work than it will be your mains filter which if blown power doesnt get to your machine if the machine is brand new and has manufacturers warranty then these are covered through the warranty and any tampering will void your warranty though should be covered for no less than a year
Nov 26, 2006 | Hotpoint Aquarius WD640 Front Load...
Kenmore 44102 Front Load Washer Logo
106 people viewed this question
Sal De
 Brian Main
Brian Main
