Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Lexmark x7170. Ran out of ink during incoming fax. How can I retrieve the missed fax.
  • 2,120 Answers
You can't ,once it exits the machine the fax is completed. If you print out a journal you might be able to tell who sent it.
Posted on Jan 07, 2009
Lexmark X7170 will not print in grayscale
i have cannon 3530 xerox machine ... it shows error code 350 ?? any solution ??
Jul 28, 2013 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Where is the ink cartridge located on the lexmark x7170
Please refer the Lexmark X7170 User's Guide for more detailed instructions on how to insert/replace ink cartridges in your printer. Go to Maintaining your All-In-One for the step-by-step instructions.
I hope this helps.
Jan 09, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
How do i print a fax stored in lexmark x5495 if a fax is sent and does not print out, is it saved anywhere for me to retrieve
When an incoming fax is stored temporarily in the printer's memory, chances are, one of your cartridges has low ink level. To retrieve stored faxes, current state of printer must be on the instance when the fax is temporarily sent to printer's memory. Replace your low-ink cartridge without navigating away from the Fax function. Once you have replaced the cartridge, press Ok button to continue printing the fax.
Jun 21, 2011 | Lexmark X5470 All-In-One InkJet Printer
I want to retrieve a fax sent to me last year
I'm afraid your printer does not have the capability of retrieving faxes sent last year.
The only time you can retrieve faxes is when you get "low ink level" notification while a fax is coming in, where the incoming fax is temporarily stored in the printer's memory. You'll be asked to replace the low ink cartridge (without navigating away from the fax function) then hit Ok to receive the incoming fax. Other than that, you won't be able to retrieve previous faxes.
Apr 10, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have lexmark x7170 all in one printer and i can't receive faxes it says memory full but when i try clearing it it says no pending faxes so i cam't. What can i do?
This temporary storage of fax may happen when one of your cartridge is detected low ink level. Try to replace your low ink cartridge. Sadly, if you have navigated away from the fax menu after inserting a new cartridge or clearing the message, you may lose the fax. You can try to have the sender resend the message. When this problem happens again, just replace your cartridge without turning off your printer. Once inserted, accept the incoming fax message to print it.
Feb 16, 2011 | Lexmark X7170 All-In-One InkJet Printer
We can't receive a fax!!! how are we supose to connect with a phne line and the computer???
You don't need to have a computer plugged in to the Lexmark printer to receive faxes. Here's an article on How to Configure the Lexmark X7170 to Receive Faxes. Just click on this link: If you are sharing your home phone line with the fax and you have an answering machine on the same line, make sure to configure the answering machine to pick up first then the fax machine. Voicemail feature can also block incoming faxes. Once voicemail picks up the fax, signal won't be passed on to the printer. But if you want, you can also contact Lexmark technical support to further investigate the problem.
Aug 12, 2010 | Lexmark X7170 All-In-One InkJet Printer
Lexmark x7170 printer cartridge error
Remove the color ink cartridge and double check that the plastic tape, which you removed from the cartridge is completely removed. I've noticed that sometimes a small piece of the protective tape tears and stay stuck on the cartridge causing the printer to give a false error. When replacing the cartridge be sure its fully inserted into the color cartridge holder and the locking mechanism locks securely.
Jan 17, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I can receive faxes but when I send them they are illegible.
make sure glass is totally clean and pad is clean, also could be an issue with your scanner bulb
Feb 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
Message wrong cartridge on lexmark 7170 printer
for Lexmark x7170 ink cartridge is #32 and #33.
double check the number on the ink cartridge. and make sure to take the tape off the bottom of th eink cartridge before insert it in the cradle.
as far as the cleaning. there are contact pins in the ink cradle and on the bottom of the ink cartridge.
clean them using a coffee filter with little alcohol.
Dec 03, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
