How do you replace the pull chord on a toro 521 snowblower
SOURCE: toro 521 snowblower..nn replace gas line to carb,
Or, you can try the easy approach. Take a 1/4" bolt about 2" long and cutoff the head. Force the bolt into the old fuel line on the fuel tank side (after removing fuel tank), push other end into new fuel line, tape the lines together well with electrical tape. Gently pull from one side and push from the other until new section of line comes through. Just did this and it too all of 5 minutes.
SOURCE: i have a toro snowblower. i cannot pull the pull
Pull your spark plug out and see if the cord will pull out, if it does than that means your cylinder is full of gas which is a result of ethanol in the gas causing the needle valve to leak causing fuel to siphon from tank to cylinder, pull your carb off and put a carb kit in and you will be blowing snow in no time,if this isnt the problem then enjine may be seized up and its time to replace blower. Good Luck!
What is the model and serial # for both the snowblower and engine ?
