Connecting KLH subwoofer to a Sony receiver
I am trying to connect a KLH audio systems amplified subwoofer system model # ASW12-200B, frequency resp: 24 to 40-180hz, 200 watts to a Sony receiver and I can not get any sound from the subwoofer. Any advice on how to hook it up?
  • Kelly Lowery Jan 07, 2009
    Thanks for the advice and links. We did actually have it hooked up correctly. My husband tested the speaker and it works so we are thinking there my be a problem with our receiver. All the other speakers sound great it's just the subwoofer that we can not get sound from.
  • 2,071 Answers
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
I have a Jensen KS212 and I'm connecting it to a home theatre receiver direct to see if it works but nothing comes out of it. Does this mean the sub is not working or there's not enough power from...
Hi, welcome to FixYa..
Your subwoofer requires a seperate amplifier that has low pass filter in the pre out system, which means it will allow all low frequency signals from the input section of the amplifier/ crossover. Your receiver has combined signals of high, mid and midbass signals that will not be able to drive your subwoofer. That is the main reason why some receivers has "Subwoofer Out" to allow you to use "Active Subwoofer systems" (also known has self powered or has a built in amplifier w/ subwoofer)
For you to use your Subwoofer, it must have a seperate amplifier, connect it to Sub out of your receiver and from there you can hear the difference. Hope this helps.
Jul 13, 2011 | Jensen KS-212 Car Subwoofer
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
Can I hookup a Sony receiver STR-DE505 to a Bassbite 2 KLH Audio system and how??
Yes.
It's frustrating that KLH manuals seem impossible to find anywhere online BUT a simple picture will suffice...
Go here and supersize the picture of the rear of the sub...
http://cgi.ebay.com/KLH-Audio-Systems-Bassbite-V-Model-E214708-Speaker-/110673631693
Run your front channel speaker wires to the CLEARLY-MARKED connectors on the sub and daisy-chain your front speakers to the CLEARLY-MARKED connectors on the sub.
Adjust the sub volume to match the front speakers levels. This will give you local volume control at the Sony.
Jun 04, 2011 | KLH BB-II Subwoofer
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
Connect a Sony SA-W3800 powered subwoofer to a kenwood receiver
Yes. It needs to know you have a subwoofer or it won't send low frequencies out to one. Then you have to calibrate its level to match the rest of your speakers. Hit the SETUP section in the manual (available at retrevo.com).
Jul 02, 2010 | Kenwood VR-309
Connecting an Altec Lansing ADA995 subwoofer system to a stereo
I have this exact Altec Lansing speaker system and I'm currently just using it with my Dell computer. But, I know you don't have to install these speakers to any high powered receiver for good sound quality. The subwoofer has two separate 200 watt RMS combined amplifiers built in for it's single knob controlled dual 6.5" bass drivers and 2-way magnetically shielded satellites, which are amplified together by any source that has an analog or digital volume control. The speakers act as a preamp receiver to any volume or frequency tone level controlled audio source. These input sources can also equalize the speakers receiving input signal for bass, treble or mid-range adjustments. You only need to obtain the proper adapter to hook up all the speakers to your desired component or device. Besides a computer, for example a TV with a variable audio out function or a mp3 player will work. The adapter that i am referring to is similar to what is included with certain 5.1 Logitech brand computer and multimedia speakers specifying gaming console and TV connecting. It has all three color coded 1/8" connector inputs on one end and RCA jack outputs on the other. This can be purchased more easily online then offline at stores such as Ebay for a fairly inexpensive price. However this adapter will not decode true 5.1 surround, but instead give a 5 channel stereo effect. I guess if one was looking for an inexpensive alternative solution to purchasing traditional high end home entertainment audio equipment, the ADA 995s are one of few computer speaker models in my book that can do a decent job.
Jun 19, 2009 | Altec Lansing ADA995 Speaker
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
865 people viewed this question
 Grubhead
Grubhead
