Question about iLO XM-MP3-CD Car Stereo
My stereo has satic while the vehicle is running...but when the engine is off there is no issues...
  • 4 Answers
It used to be the condensor on distribtor that caused the same problem on my old granada changed it no static
Posted on Jan 06, 2009
Check engine light will stay off for long and seem to have an electrical issue
Check engine light back on ???? What DTC'S - diagnostic trouble codes are stored ? Need to know that to assist you . After a battery disconnect on GM vehicles you need to enter a code into the radio for it to work again . Not all GM vehicles are like this , i will have to look that up I come back later ! Time to take kids to school .
Apr 11, 2017 | 2003 Chevrolet Chevrolet Tahoe
Why van does not start after new stereo installed?
Depending on the year your vehicle was manufactured it is most likely that when your stereo was installed they interfered in some way with your wiring related to your ignition wiring. I would recommend if you had the stereo installed professionally to call them and let them know your having the vehicle towed to their place of business and that there was no such issue prior to them installing the stereo.
Jul 31, 2014 | 2003 Chevrolet Venture Passanger
When the vehicle is off and stereo is off the speakers are making loud popping and banging noises all the time over the last week? when the vehicle is running and stereo on no popping noises
This can be tricky; there are several things that might cause this 'phantom' problem. You did not state if you have an alarm system. The alarm may be tied into your speakers and/or linked to the stereo itself. I would not initially suspect a ground issue since the stereo works well while powered. I would suspect a power feed issue. This can be tested by removing the fuse for the stereo and seeing if the issue continues.If the problem stops, the source may be internal to the stereo and you may need to get an aftermarket stereo - or pull the fuse every time you stop ( sucky solution, I know!) . I think this may be an issue resolved by a reputable stereo shop. Possibly a strategically placed Diode may solve the problem - a hands on diagnostic is certainly called for. You did not mention if the problem decreases or stops overnight. I would think this can cause your battery to drain over an extended period of time - and ruin the speakers too, if they're not affected already. I would try contacting the Dealer first and, as this problem has gone unresolved for so long, see if you can get them to replace the stereo or at the least pay the stereo shop to fix it.
best of luck and thanks for using Fixya!!
Feb 17, 2014 | Audio Players & Recorders
93 toyota 3.0 v6 stero goes off then engine dies has to be jumped off runs several miles dies again i replace alternator crank vehicle without jumping it off drive it 20 miles stereo shuts down and engine...
this sounds like an external voltage regulator issue..when it gets hot or shuts itself off the battery is whats running the vehicle..until the operating voltage drops below minimal.. then it all stops..get the charging system checked at a parts store.. they do it for free..
Dec 22, 2013 | Cars & Trucks
My stereo restarts when I shut off the car engine even though I am leaving the key in the 'on' position.
This forum is for video cameras and camcorders. Please repost this query in a forum dealing with vehicle accessories. Thank you
Mar 12, 2017 | Kenwood Video Cameras
What would cause stereo system sound to go out when door chime went out?
GM vehicles 2001 to about 2004, they tried running alot of things thru the stereo. Door chimes, security system, key fob reset. This didn't work too well as when the stereo breaks, so does everything else. You might have a bad stereo, or maybe (depending on your vehicle) the amplifier that runs the speakers might have pooped out. You can do an aftermarket stereo and they sell a wire harness that bypasses the amp. Just a suggestion. The wire harness for those year GM's is about 150 bucks, plus buying the deck. Like I said, just a guess and a suggestion.
Apr 25, 2012 | 2003 Chevrolet Tahoe
We have a motorhome and were getting engine noise through speaker
ok,,,this is an easy one to fix,,,
its a cracking or screaming sound ,,,right?
its off the car spark plugs and from the plug leads,,,
you havent fitted any serpresors to the plug leads
you can do one of two things here buy new plug leads plus the coial lead but they must be suprested leads,,,or just buy the suprested caps and fit them yourself,,,its best to buy new leads,,,when you fit them only pull one lead off at a time and fit the new lead to the one you pulled off that way you cant get in a mix up,, its very unlikely the alternator will cause a buzzing but they can at times,,,check that the radio ariel is earthed to the car body,,,it must be earthed!
Jul 03, 2010 | 2006 Sterling 825
Pioneer deh-p9800bt is makeing a bad noise thrrough my speakers
Since vehicles started using High Energy Ignition engine noise in stereo equipment has been a issue. You have two options. The first is to try connecting your power wire to a alternate source that may have internal filtering. If you cant find a clean source of power you will have to add a inline filter on your power wire. You can pick them up at any stereo shop.
Nov 20, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Car stereo
does this always stay on when the car is running? What is the make, model, and year of the vehicle? Possibly, you are connected to an incorrect power lead or have a bad ground.
Sep 16, 2008 | Car Audio & Video
iLO XM-MP3-CD Car Stereo Logo
87 people viewed this question
Top iLO Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Libran Moreno
Are you an iLO Car Audio and Video Expert? Answer questions, earn points and help others
