Question about Belkin Wireless-N Wireless Router with 4-Port Switch
I have a Belkin Wireless N Router and the virtual ports is.....
Giving me problems, I need help with this and I have all my information in the Virtual Servers port But i press APPLY CHANGES and then i went to Google and searched PORT SCANNER And then i went to one that i TRUST. And scanned my ip and port that i have for my Virtual Server. It says (MY IP) is not currently running on (PORT)  PLEASE HELP!
    Problem Solver:
I fixed all i had to do is just find out my IPv4 Address
Which i found by searching CMD and then typing in IPCONFIG and press enter.
Then look for your IPv4 address and put that in the private ip address part in Virtual Servers.
Posted on Jan 08, 2009
How do I open My ports on my router
This referred to as Virtual Servers in the Web Admin.
This site is for gamers, but use it as a demo. Its the same principle / steps if you need to setup some other application.
Choose your Belkin model (but I think they are all the same), then any game to see steps and screen shots.
http://portforward.com/english/routers/port_forwarding/Belkin/
Dec 12, 2012 | Belkin Basic Wireless Router
How to change my NAT from moderate to open for xbox live
you need to setup your xbox 360 with a static ip address
after that login to your belkin router
and click on virtual server on the left.
then add the following ports 53,80,88,1863,3074.
Apr 11, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hello I have a belkin router model # F5D7230-4V9000 with serial # 140849R7901012 having IP address of 192.168.2.1 . I am trying to connect a DL wireless camera Model # DSC-920 but it connect and shows...
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
step 3 :click on firewall disable the firewall
step 4 :click dmz - >type in private ip 192.168.2.25
step 5:click on virtual server type description camera inbound port 0 and type tcp&UDP or Both and private IP is 192.168.2.25 and private Port 65535
( Or )
In order to configure this, you need to know:
- The IP address of the computer or device to have the port forwarded to.
- The port numbers to be used and whether these are TCP or UDP ports
(Note: We recommend you use a computer that has a wired connection to the router.)
Setup steps:
  1. Open a Web Browser on the computer. Type in http://192.168.2.1
  2. In the address bar of the Web Browser type Click Login in the upper right hand corner of the page. The router does not ship with a password, so just click submit.
  1. Click on Virtual Servers under Firewall in the menu on the left
  1. Enter the following information
    • Click Enabled
    • Type a general description of the application i.e.. Remote Desktop
    • Type the port(s) specified by the program manufacture for both of the Inbound port fields
    • Select TCP, UDP, or BOTH for the Type.
    • Private IP address: Enter the IP address of the computer you want grant access too.
    • Type the port(s) specified by the program manufacture for both of the Private port fields.
  1. Click the Apply Changes button
Jan 30, 2011 | Belkin (F5D7231-4) Wireless Router
I am having issues setting up VPN using the Belkin F5D8231-4 Wireless Router. Please help.
connect your computer wired to the router
open the internet explore type this in address 192.168.2.1
on left side grey vertical column click on firewall - disable firewall
on left below firewal u have virtual server click on it and just add this port number which i give
open the following ports in the router
Vpn ports no: TCP- 1723,443,10000
UDp- 1701,500,50,51
when u open this ports your VPN wil work for you
Let me know if it works
Thanks & regards
Milan
Jan 08, 2011 | Belkin (F5D8231-4) Wireless Router...
Problem with NAT type for xbox live? I have a Belkin wireless G Plus Mimo router and i have strict Nat type when geting on XBL. Any way to make this open?
yup....you can login to the router setup page by typing 192.168.23.1 in internet explorer...
on the left side you will find an option called firewall....click on that..it ll prompt for the password..(password: leave ot blank and click submit)
go ahead and disable it...
also click on DMZ on the left side of router setup page and enable it for the IP address assigned to the XBOX...
also get into virtual servers on left side and open common gaming ports like,
port 80
port 88
port 3074
port 53
port 443
for both tcp and udp....
in addition to that you need to open ports suggested by XBOX vendor...
thats it, you are done with that....as you open ports for xbox in virtual servers
the particular ports for xbox gets bypassed from NAT...so you need not worry about NAT hereafter...
also make sure that the modem provided by the ISP is not NAT enabled...if so ask the ISP to Bridge the
modem,so that you would not face further issues with XBOX....
Apr 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I can't play my PS3 & Comp. at the same time with my router
try assigning a static IP address in the range of belkin router for your computer and PS3...that is 192.168.2.X (where X = 2 to 254)
the default gateway should be 192.168.2.1.... Log into your router and enable DMZ for the IP address assigned to your PS3...Goto Virtual servers in the router setup page and open the concerned ports for playing games in your computer(enter computer IP here in virtual servers)....the common gaming ports would be,
port 80 TCP,UDP
port 88 TCP,UDP
port 3074 TCP,UDP
port 53 TCP,UDP
click apply changes and try playing now... you can also restart the router for working better.... enjoy....
Mar 09, 2010 | Belkin F5D7234-4 Router
Have blkin 54 - cant upload to my website, keeps interrupting me with belkin homepage
simply goto admin 192.168.2.1 or 192.168.1.1 or 192.168.0.1 you got to tell the router that you wish to kee p the port 21 open for ftp Firewall > Virtual Servers and add a entry using the port 21 and restart the router. Regards GeWiz
Apr 19, 2009 | Belkin (F5D8231-4) Wireless Router...
I have a belkin wireless g router and my nat settings are strict?
I understand your problem..To fix this issue all you have to do is,You should open the x- box port numbers on the belkin router(please call tech support for assistance),
And also i would suggest you to assign static ip on x-box on belkin range(192.168.2....) then you need to enter same number on router under DMZ. It may be quiet difficult for you to do all this.please call toll free number"belkin".
Dec 17, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin router F5D7230-4
Not sure wanting help to download illegal music is available here.
Jan 07, 2008 | Belkin (F5D72304F5D7000) Router
Open Questions:
Belkin Wireless-N Wireless Router with 4-Port Switch Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
