Question about Frigidaire 24 in. GLD2150RCC Built-in Dishwasher
Kenmore Dishwasher 665 1587580 troubleshoot
Hello!
I smelled something burning, my husband checked the dishwasher and thinks the circuit board burned up. Can you offer any assistance in figuring out the exact problem and if it is worth fixing? We aren't quite ready to buy a new one, yet, but will in the future as this is an old machine.
Thank you!
    Novelist:
  • 108 Answers
Well, chances are it is the control board, but you will want to cut the power to the unit (at the breaker box if possible) and open the door panel by removing the screws on the edges. Make sure there isn't a crack that is allowing water to get on the board.
The control board can be a bit intimidating when you look at it, but replacement is quite easy. A search with the term "control board" and the model # (use the model number on the sticker inside the door of the dishwasher) as well as the brand, and you should find a number of places to get one.
Just remember to change the board with the power off, and move the plugs one at a time to the new board so that you don't get confused.
Posted on Mar 24, 2009
Electrical burning smell coming from control panel on westinghouse dishwasher
Had the same issue with a 903sa. Strong burning smell. Continued to run for a while then just died. Opened the control panel (4 screws holding the plastic part at the top of the door on - open the door to access).
Mains feed into the controller was totally fried. Case was all melted. Very nasty. There was nothing obvious on the Board other than a mains resistor that looked like it had been pretty hot at some stage. The three pin mains connector (at least I think it was 3 pins) was just a big, charred bit of goop.
Feb 09, 2014 | Westinghouse Dishwashers
Lg dishwasher smells like something is burning
This is an interesting problem and it requires some testing equipment to see what the problem is. You have to check the heating coil if it is a washer that heats the water. You also need to check the control board and some other things to see if you can locate the source of the burining smell. To perform these checks requite some test equipment like a meter.
May 22, 2013 | Dishwashers
My dishwasher by Frigidaire Gallery Professional Series Model gpd8998jc0 has all lights flashing and could not be started. I smelled burning from dishwasher. Could it be motor burning?
it could be the motor depending on where it's coming. You can remove the lower panel, there are only two screws that hold it on. Look under their and inspect the motor.
Another part that could cause this issue is the mother board. The board is located behind the control panel. Remove the screws around the door frame to loosen and remove the control panel.
On most of these you also have to remove the plastic shielding that cover the control board. To do so remove the three or four screws that mount the board down.
Often these control boards will burn and create a smell like this.
Let me know.
Mar 26, 2011 | Frigidaire Professional Series 24 in....
I have a kenmoer 66516039402 dishwasher. It is stuck in clean mode the clean light just flashes and the dishwasher will not start a new wash.what can I do to fix it.
Re: clean light blinks seven times on Kenmore Dishwasher model # 66516034401
After reading online and studying the parts diagram/list (included with paperwork that came with washer) and troubleshooting guide/wiring schematic (located under the bottom front kick panel) I determined it could only be 5 things, all easy to look at and check when you pull out the dishwasher (remove racks first and cut power via the circuit breaker).
They are heating element, wiring check for burn marks/melting), high limit thermostat (mounted on bottom of tub against tub, detects if tub overheats), thermistor (screw in mount near motor, detects process temp inside dishwasher, and the control panel. Unfortunately, I started buying and replacing the parts piecemeal (first high limit thermostat, then thermistor, then heating element, even though it tested good). Only then did I remove the panel (top 6 screws inside door, no need to remove the whole door panel) and check the circuit board. After separating the circuit board from its plastic case that covers the back of the board, I saw that the back of the board was badly burned/blackened about the size of a fifty cent piece around the heater circuit relay (this was not visible from the front). Bingo. I should have done a comprehensive check first and save $100 on parts that were probably good. When ordering online, the circuit board part was changed, perhaps to an improved part if the relay burning out is a common problem. Good luck.
Jan 23, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
My asko dishwasher has power to the machine but the lights will not light up. We smelled a burning smell earlier in the day and I think it came from the dishwasher. any ideas?
Yes, this sounds like you r control board has burned out. This is a simpe repair and something you can do yourself to save a lot of money!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we willget the correct part out to you right away along with instructions on how to repair it.
We look forward to working with you!
Ella
Nov 09, 2009 | Asko W6021 Front Load Washer
Strange smell inside
You should have it checked, but in most cases something has gotten onto the heater element and was burned. But DO NOT, just think this,
check the element in the bottom,and look for a burn mark on it, if you do not see anything on it or a mark,then assume it is an electrical
problem, pump motor, drain motor, and have it checked. Any questions please post back,everyone is happy to help.
Mar 26, 2009 | Bosch 24 in. SHV4303 Built-in Dishwasher
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Kenmore Elite Dishwasher model 16264 electrical fire
I contacted my lawyer who advised that I file a Civil Complaint against Sears so that is what I have done.
Feb 18, 2009 | Kenmore 24 in. 16264 Built-in Dishwasher
Kenmore Elite 17483 Dishwasher Caught Fire!
Had the exact same problem (Control panel burning up, sparking, and smoking during wash cycle) last night with our Kenmore Elite DW model 665.16293400 purchased Nov. 2004. I have reported it to the CPSC and www.kitchenaidfire.com and will be contacting Sears first thing tomorrow. It is outrageous that this problem is apparently so widespread with nothing being done about it! I have no doubt my kitchen would have been in flames if I had not been sitting right here to shut off power to the D/W.
Feb 04, 2009 | Kenmore 24 in. 17483 Built-in Dishwasher
Smelled like burning plastic
Ron, is this a dishwasher or clothes washer? If a dishwasher, check the wire nuts in the junction box. If there isn't a melted wire nut from a loose connection. Then you have to pull the outer door panel, then you can pull the control panel assy. This will require a t20 torx bit.
Jan 04, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire 24 in. GLD2150RCC Built-in Dishwasher Logo
269 people viewed this question
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
