Question about Bissell 6700 Butler Revolution Bagged Canister Vacuum
Need rreplacement hose for bissell 6700 butler revolution caniste
Do you know where i can buy a new 6700
  • 126 Answers
You might give bissell.com a try. Good Luck.
Posted on Jan 07, 2009
Bissell butler revolution disassembly
We have a network of BISSELL Authorized Service Center for warranty repairs. If you are experiencing difficulties, the technician will let you know the cost for those repairs if your machine is outside of the one year warranty timeframe. You can locate a BISSELL Authorized Service Center at this link: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&icid=ccrr
Jul 24, 2012 | Bissell 6700 Butler Revolution Bagged...
Can't detach vacumn hose from hose grip base to clean with canister.
turn it 90 degrees to release it , if you look you will see ( unless its reallly dusty ) 2 tabs that are inside the hose attachment itself
May 08, 2011 | Bissell Lift-Off(R) Revolution(R) Turbo...
No suction with attatchments
if you have cleaned all the filters, there are two you need to wash and the hepa on the back may need to be changed, but the hose is probablly clogged. You can usually remove the hose ( twist it where the hose connects to the machine ) and use a broom stick to try and push the clog out.
Jan 12, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Jan 04, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Bissell Lift-Off Revolution keeps clogging
Sounds like it is partially clogged. That yellow thing you are talking about, twist it and it should come out, clean or replace the filters, then re-install it. Check the hose and make sure there isn't a clog in it and clean any other filter. One problem with this bagless is the filters will clog up fast and need to be cleaned on a regular basis. Another place a clog happens is in the inlet by the brush roll.
Nov 07, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Sounds funny/shutting off after few minutes
Yup! Clogged hose on the back of the cannister! Unit is designed to shut off for 30 minutes when this happens to protect your motor. Remove top of hose where debris enters the cannister through a filter above it, then remove the other end of the hose from the bottom of the back of the cannister, take it outside and use something long that'll fit inside the hose to force out all the clogged debris and hair through the top of the hose.
Oct 17, 2008 | Bissell LiftOff Revolution Pet Vac 37602...
Clogged Bissell
Something must be in the hose causing a clog, take the hose off and if suction is good where the hose hooks up, then there is something caught inside the hose.
Mar 23, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
FAN PROBLEM???
There isn't any belts, and the fan wouldn't be rubber, so not sure what you are smelling. Maybe this picture will help you.
Dec 30, 2007 | Bissell 6700 Butler Revolution Bagged...
No suction
Is there a blockage in the small hose in the bottom of the machine
take of the pod and you will see the small hose,
Is the main hose pushed into the bottom housing
Nov 06, 2007 | Bissell 37603 Upright Vacuum
Bissell 6700 Butler Revolution Bagged Canister Vacuum Logo
145 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
