Question about Sharp EL-2615G Calculator
The ribbon is no longer printing on the tape.
I feel the ribbon is too new to need to be replaced. Is there a switch to have the ribbon tape reversed to run the opposite direction (like the ribbon typewriters used to work)? Thank you.
  • Anonymous Dec 19, 2007
    royal calculator replace little ink roll don;t know which way it goes int 550hd thanks sharon hinonskis@aol.com
  • Anonymous Mar 13, 2014
    RIBBON JAMMED AROUND A WHEEL HOW DO WE RELEASE
  • 186 Answers
Are you sure it uses a ribbon? Or does it use an ink roller. If it uses a ribbon it should reverse by it self. Make sure it is installed properly, there is not a ribbon reverse switch it should do it automatically. if its installed right.
Posted on Jun 17, 2007
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
Install lift off tape cartridge
Remove the ribbon by pushing the blue lever to the right and front of the ribbon. The correction tape cartridge is attached to the bottom
of the Printing ribbon. Depress the center of Printing ribbon to release the correction ribbon. Snap on a new one.
Nov 04, 2013 | IBM Personal Wheelwriter 2
Zebra S600 not printing..replaced ribbon withe as paper/ribbon light solid..still no print after attempting reprint many times (the printing result are white labels)
Just a thought, Zebra Ribbons are Coated Side Out. Take a piece of tape and press it against the ribbon, ink should come off on the tape.
If not then make sure the ribbon is the correct type and that you have it loaded properly. Also, if you use multiple ribbons i.e. wax, wax resin or resin make sure that you have the correct ribbon for the media installed.
Hope that helps.
mikeo@acebarcode.com
www.acebarcode.com
Aug 21, 2011 | Zebra Stripe S400 Label Printer
Good afternoon, I am having problems getting my printer to print a complete card without telling me that the ribbon is broken. The error code I am receiving is PR-01724 The Printer I am using is the...
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Jun 20, 2011 | Datacard SP55 Plus Printer
I installed a new cartridge ib my Brother GX 6750 and it is not printing..The keys are working fine however it is not hitting the tape to print.
Hi!
Neat little typewriter.
Think back, and reverse the steps.
Before you removed the finished ribbon, you had to pull on a little lever that is next to the printhead, right?
Now that you inserted the new ribbon, you must push that same lever towards the platen, away from you, in order to lock it back in the normal printing position.
Please feel free to contact me if you wish.
Feb 13, 2011 | Brother GX-6750 Typewriter
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
Wheel writer II will not print - replaced with new ribbon
There's a small cap on the solenoid that pushes the hammer, this cap wears out and the solenoid cannot push anymore. Cheap part, always wears out, new ones are teflon and last lots longer.
Jul 27, 2009 | IBM Wheelwriter 30 Typewriter
When I type it is printing different letters than I am typing.
On most models there is a pitch switch 10.12.15.PS
you need to match the switch to what print wheel is in the typewriter. most common wheels are 10 or 12
move the switch to that area.
if that is not the problem take out the ribbon, corr. tape & print wheel. tuen on the typ. let it home, put the print wheel & ribbon ( Not the corr. tape) turn on let it home tray typing. if works O.K. put in the corr. tape .
Then you are good to go.
Jan 29, 2009 | Office Equipment & Supplies
Liftoff tape doesn't work properly
It could be the ribbon is not seated properly try removing it and reinstalling, or did you remove the tab from the ribbon cartridge top either orange or red coler and did yo wind the lift off tape into the takeup spool show the leader is no longer exposed?
Aug 20, 2008 | Office Equipment & Supplies
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Sharp EL-2615G Calculator Logo
731 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
