Question about Samsung SyncMaster 205BW LCD Monitor
Monitor Slowly Tilting More & More Towards the Ground
I have a Samsung SyncMaster 205BW 20.1" widescreen monitor that I purchased about 3 months back. When I set it up I was very happy with it, and the picture still looks great. Here's the problem: Slowly, but surely, the monitor is tilting more and more towards the ground. As if the base and support are not strong enough to keep it at a clean 180 degrees from the desk. No amount of pushing, pulling or other brute force methods have worked so far... Any suggestions?
  • 1 more comment
  • Lucyky Nov 30, 2007
    Mine cannot be adjusted back up to a comfortable level. Does anyone know how to adjust it back up? I would be happy to velcro it, or whatever, if I could just get it back to a comfortable viewing level. I was gone for several months, and it seems when I returned, my monitor is in this shape. I can't find anywhere to adjust it.
  • llesle Dec 30, 2008
    I have exactly the same problem with monitor tilting forward Has any one figured this problem out.
  • kv32 Jan 01, 2009
    Same problem here.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Unsnap the c shaped cover from the joint area, No screws need to be removed, but you need to tilt the screen so that it will clear when removed.
What you need to do is slip a penny under the two springs which provide tension to the tilt. You can do this by prying them up and pushing a penny under them. Next, you need to increase the friction in the pivot (this alone may be enough to solve the problem.) Several things might work. I used a Permatex thread lock compound and just dripped into the pivot area and let it dry overnight.
Works perfectly now, and I can always add more thread lock easily.
Posted on May 08, 2017
    Problem Solver:
  • 22 Answers
I am not a monitor expert, but from product photos, it looks like the flat panel is mounted on a weak pivot, probably a design fault. I would guess that you probably don't want to spend a lot of time on this problem, and don't wish to make it worse. If it were me, I would probably use some sticky-backed velcro on the panel and base so that the velcro would hold the panel up, and still be adjustable... if the monitor's back is against the wall, it won't be seen.
Posted on May 30, 2007
  • Ken Christensen
    Ken Christensen May 31, 2007
    I didn't see any, but you could also try to see if there was some way to tighten the pivot. But, with so much plastic being used nowadays, there usually are no screws etc, and even if there were screws in such thin plastic, they might strip-out under the additional stress.
    If nothing else is obvious to do, just remember that you'll probably replace the whole monitor in a few years and it just won't matter anymore. Only watch out for the next monitor you buy, when the time comes.
Dead pixel
It might, somes companies won't honour warranty unless you have 3 to 5 dead pixels. Go to www.samsung.com and contact customer support to see what can be done.
May 09, 2012 | Samsung SyncMaster B2030 20-inch...
OUR sAMSUNG sYNCMASTER 205BW has a red tint in the background and cannot adjust it out.
The red or pink tint indicates that the back light florescent bulbs are failing. These bulbs are just like the bulbs in home and office lamps just much much smaller. When the reach the end of life the light output turns from pure white to red because the bulbs are not fully turning on. Check the manufacturer date on the back of the monitor, if its less than 3 years then the monitor is still under warranty. If its older than 3 years then its time to get a new monitor because your is about to fail.
I hope this helps, if so please rate my solution.
BuddyMc
Sep 15, 2011 | Samsung SyncMaster 205BW LCD Monitor
CAN A SYNCMASTER 205BW BE USE A KAROKEE MONITOR
Yes. Any LCD monitor with built-in speakers can be used for KARAOKE.
Apr 20, 2011 | Samsung SyncMaster 205BW LCD Monitor
How do I adjust the tilt function. It seems it is stuck
Tilting on most Monitors is designed to require some force to prevent it from slipping.
Gently yet firmly hold down the base of the monitor on the desk with one hand. Then place a second hand on the bottom of the screen and pull it towards you using even pressure. It will slowly move.
Please also keep in mind that your monitor may not be able to tilt much. If you need it to tilt further, you can buy an alternative stand for it.
Apr 07, 2011 | Samsung SyncMaster 740BX Monitor
Samsung Syncmaster 205bw does not power up. Power button light comes on and cannot turn it off by pushing it.
The processor ic has malfunctioned and is the brains that controls various parts of the monitor, including on/off, picture settings and others to numerous to mention. The monitor is not cost effective for repair and is cheaper to replace.
Jan 13, 2011 | Samsung SyncMaster 205BW LCD Monitor
My samsung monitor, Syncmaster 205bw has a dark picture and cannot adjust?
You may have failing casp in the power supply (common problem) or lamps. See pictures here so you will have some ideas as what to look for.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Post back.
Apr 08, 2010 | Samsung SyncMaster 205BW LCD Monitor
Do I need a disc to install our samsung syncmaster 205 BW monitor? If so, where do I get it?
Is this a new monitor, and there is no disc with it?
If you are running XP, Vista, Windows 7 etc. than the monitor is plug and play. Just turn the computer off, plug in the monitor, turn on the computer, and you should be good to go.
Aug 05, 2009 | Samsung SyncMaster 205BW LCD Monitor
Brightness automatically going low when the brightness is at 100
hello, please make sure the magicbrite option is not set to "dynamic contrast" as this will change the contrast levels by itself, change the settings by pressing the down arrow touch key on the monitor, change it to any other setting, game mode is blinding on my one (when the monitor works, but thats another story!!!) good luck with samsung customer care centre 0870SAMSUNG (uk)
Apr 04, 2009 | Samsung SyncMaster 2493HM Monitor
Samsung SyncMaster 205BW LCD Monitor Logo
357 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
