Question about Moen & Knob Handle Kit
Broken shower knob
The knob in our stall shower turns the water on and off by pulling it in and out. The shower knob broke off and what we have found is that the screw that holds the knob in place broke in half and is now lodged inside the piece that is in the wall. How do we repair this problem? Do we have to call a professional (we're hoping not to have to spend the money to do so)? Any advice is appreciated.
  • 334 Answers
You need a screw extractor.broken shower knob - 51nxsfhdrzl._sl500_aa280_.jpg
One end drills a hole into the remaining part of the screw. The other end fits inot the hole and turns counter clockwise, gripping the screw and removing it.
You can also buy a bolt extractor which will fit over the stub of the screw. This may work better if you have enough room to access it due to the small diamiter of those screws.
http://www.amazon.com/gp/product/B001A4CWHO?ie=UTF8&tag=christianande-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B001A4CWHO
Otherwise, breaking off the surrounding pieces of plastic from the handle and removing the screw with pliers and replacing the handle is about the only way.
Posted on Jan 06, 2009
Shower button came out
you can use piece of cloth over there
Nov 09, 2013 | Plumbing
Push Pull Shower Valve also off in middle position
If you turn it to left or right (hot or cold) and get water out of the shower head,we'll elimate cloged shower head.If it just doesnt work in the middle ,probily a washer is stuck in your diverter,or to better understand>a part inside your shower knob assembly is clogging the water that goes up to your shower head. If you get water out of the shower head in the just cold possition or just hot position,then you will have to dissasemble the unit to repair. If you get no water in the cold or hot position could just be a clogged shower head.If you dont know how to disasemble a Shower diverter ,I wouldn't recommend taking it apart. Hope this helped!
Feb 09, 2012 | Moen Home
Knob on tub spicket to release or stop shower came off
I could not find an exploded parts diagram for the Benton suite from Moen. I did find the bayhill which is very similar. Please see link below of exploded view. That should help you piece it back together.
Jul 31, 2010 | Moen & Benton& Tub & Shower Faucet
Water comes from both the shower head and bath tub faucet when bath is turnd on and wont turn off when shower is on
if it is standard shower where you pull the knob up when water is running. the pull knob lifts a flap to shut off water to bottom faucet it proably has some buildup on the flap clean well with some clr or other calcium cleaner like it so the flap gets a clean seal on downspout
May 08, 2010 | Home
Broken rollers on shower door
The rollers for most shower doors are a stamdard size and are available at most hardware stores. The Bigbox stores might even carry rollers for you specific make and model.
Feb 25, 2010 | Aqua Brass Prestige Shower Kit #2 AQUA...
I have a Moen shower knob that broke...
You are not the first. Usually you must break the plastic handle to remove it and then you can access the screw and have leverage to hold the brass stem with pliers while you try removing the screw. Caution, do not try to bend the handle to break it off or you will break the brass facet stem. Also, there are two styles of handles: one has a short innercone,the other has a longer inner cone. You need to know this before you purchase a replacement. Goodluck< Macgivor
Dec 27, 2009 | Moen & One Handle Tub & Shower Faucet
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Jan 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Moen & Knob Handle Kit  Logo
1,152 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
