Question about Vector 955 Radar Detector
Beltronics V955 Chirps on all bands for 10 minutes when cold
Bought this Circuit City a few months ago when the weather was still warm. Since then, we've dropped into the 30s and 40s, and it goes crazy every time we turn on the car (it stays in the car). It'll continue alerting on every band for approximately 10 minutes until the car is sufficiently warm. Of course, by that time, we're usually where we wanted to go, or we've unplugged or muted the thing.
Thx.
  • 134 Answers
This is most likely caused by a poor connection between the antenna ridge and the local oscillator board. Another possibility is an uncontrolled LO chamber harmonic due to the cold temperatures. Regardless of the cause, your V955 is under warranty and Bel will fix it for free -- as long as you include a photocopy of your sales receipt. Go to Bel's web site (www.beltronics.com), and either call their 800 number or do the online chat in order to get a RMA number.
Posted on Mar 19, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
-17 degrees centigrade started van drove in reversed for 10 seconds after which van would not move with engine idling and transmission in gear move transmission lever to drive van would not move. Move...
Most likely in this severe weather the fluid and the bands in the transmission need time to circulate and warm up. It is a good idea in severe weather to allow a vehicle to warm up for at least 4 - 6 minutes before driving it. Remember that oils and lubricants get very thick in cold weather.
Jan 03, 2014 | Cars & Trucks
Reduced engine power
What weight oil are you using? You could try using a lighter grade oil. Maybe a 5-30 or even a 10-40. The thicker grades are like corn syrup in the winter months. That's why it runs ok after you've let it warm up for a few minutes. the thicker oil has thinned some. allowing everything to rotate freely. You might even want to try some Lucus Oil Additive. It's worth every penny it cost and might take care of your problem all by itself. Good luck, I hope I was of some help.
Nov 14, 2013 | 2002 Chevrolet TrailBlazer
2003 Saturn Ion won't start in the cold weather
First of all your service light came on so give it a service then have the service light reset then check the thermastac, water levels and the choke is working properly and all the elecric working parts are good
Jul 05, 2017 | 2003 Saturn ION
My car won't start in the cold weather. I don not have Power Locks or Power Windows. What is the Problem?
That sounds like a battery issue. Batteries have whats called CCA (cold cranking amps) it is the main thing to pay attention to. This is a measure of how much current the battery can provide at 0 deg F. Batteries work better when they are warm, so the colder it gets, the less current it can provide.
Starting an engine requires a lot of current, over a very short time. Meanwhile, cold engines are harder to start, requiring more power to get them going. So look at your battery and its CCA and since u said u bought the car a few years ago. You probably didnt replace the battery yet have u? Batteries usually have a life of 4-6 yrs only. Hope this helped
Jan 23, 2013 | 2003 Saturn ION
2000 GMC Jimmy-when weather is really cold will not start, meaning will not turn over. Does not make any grinding sound, any clicking sound, battery replaced just a few months ago. After trying to start...
Sounds like a stater issue. Probably needs a new starter. My 1990 was a bear to start when the starter started having issues. Could be as simple as replacing the battery ends to ensure proper connection. My nest bet would be to double check the battery. I have bought many brand new batteries and they were bad. Just a simple check will tell you a lot. Next would be the starter. Hope this helps.
Dec 29, 2017 | 2000 GMC Jimmy
Passenger side window quit working 3 months ago.
could be a wire,could be a window regulator,could be a switch,,
Oct 12, 2009 | 2003 Pontiac Grand Prix
Turn on TV no sound or picture just chirps
Get the chirping TV repair kit from www.TvRepairKits.com to fix this problem
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
2001 Kia Rio Engine Cranks, Won't Fire, Reoccuring
i am having the same problem, thought it was ful pump, no go, I heard they had problms with the fuse box and wiring harness, my mechanic messed with mine a few days ago and it has not did it since, but I am looking at changing that. GL
Aug 01, 2008 | 2001 Kia Rio
V955 does not work
Turn the unit off and then, while holding down the City and Brt buttons, turn it back on. This restores the factory default settings. Worked for mine with the exact same problem. Be sure to use the power switch though. If you just unplug the cord and plug it back in, it won't work.
Jul 27, 2008 | Vector 955 Radar Detector
Faulty Buttons
Return to Beltronics for repair. 1-800-341-2288.
Jun 14, 2008 | Vector 955 Radar Detector
Vector 955 Radar Detector Logo
202 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
