Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Camera won't take a picture
Camera seems to operate fine but when I take a photo the preview is black and when I view the memory card on the computer the photo files are there but they are just a solid black photo. (yes the lens cap is off). I have used different memory card, different lens and different battery. When I put a cf card in that has other photos on it I can view them through the camera lcd. I last used it outdoors in hot temperatures and have read the post regarding overheating but a battery change and card reformat did nothing. The camera is about three years old and is used by my schools yearbook club. I don't have the money to replace it! Any idea what the technical problem might be and what a repair might cost?
  • 4 more comments
  • Anonymous Dec 18, 2007
    I also have the same problem
  • vickifrance Apr 30, 2008
    Yup same problem camera is about 3 years old.
  • Anonymous May 13, 2008
    My 300d was 2y6m old (12,000 pics) when the shutter only took the top 1/3 of the picture last fall. Paid Canon to repair it and 2 days ago it started giving me black pics with all of the EXIF data. Talked to Canon again and they guess shutter, but I believe its the sensor since the shutter flips up and the data is there (also saw a sensor reference some where else in my searches and a bad connection - solder joint). Changed cf cards, lenses, battery, removed battery for hours to reset it and nothing helps but leaving it sit, sometimes it will take one more pic and then the rest are blank again.
  • Anonymous May 23, 2008
    My Rebel 300D is about three or 4 years old and also not taking pictures. I actually took over 600 photos today, indoors and out, when it just went black. It's trying to focus, the flash comes on, but there's nothing in the eyepiece and it won't snap. I also changed lens, battery and CF card. Still nothing. Help!
  • Anonymous Jun 07, 2008
    I have the same problem. My camera is also 3 yeras old. I'm still looking for a help. Mirror is lifting fine, but I don't know where the sensor is???
    help...pls
  • paulopereira May 11, 2010
    remove the lens and you should see a mirror, take a picture and see if that mirror goes up and down... if not there is your problem. If it does maybe the censor is dead, either way I can't see any DIY you can do to fix it :(
    Novelist:
  • 153 Answers
4 possibles on this one,
1) as mentioned the mirror isn't lifting.
2) the secondary auto focus mirror isn't lifting (remove lens) lift mirror and there is a second mirror behind the main mirror, if this stays hanging down its damaged, although normally you will get a part image when this happens
see http://www.lotek.nu/misc/EOS_300D_sub-mirror_repair/
3) shutter stuck (but should also have an error99 when this happens, put the camera in bulb and open the shutter you should be able to see the sensor.
4) sensor or associated electronics failure
if you do decide to attempt the sub mirror repair take great care, that big black cylinder is the flash capacitor and its charged to 350v and will bite hard....
best of luck
Posted on Jun 04, 2008
Clean the sensor, might fust work
Posted on Dec 18, 2007
    Problem Solver:
  • 7 Answers
It could be that the shutter has gone out or the mirror is not going up they are only rated to last for so many shots. That is what canon told me when my 10d did the same thing. I dont remember what the repair cost was.
Posted on Jun 07, 2007
SOURCE:
When i view my photos om my camera they are all there. But when i connect my camera to my laptop it open the window to view files but there are no files or photos available. But when i connect the camera...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 08, 2012 | Sony Cyber-shot DSC-H50 Digital Camera
Importing pictures
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sep 23, 2012 | Samsung NV3 Digital Camera
Photos on two separate memory cards are "read error" seems to be the pictures in the middle sections of the memory card. They won't show up either when tried to download onto computer. I...
you can try asoftech photo recovery software. You can see
http://www.asoftech.com/apr/
It tells the steps how to perform photo recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Aug 30, 2011 | SanDisk 2GB microSD Memory Card
I have a Samsung TL225. I haven't dropped the camera, everything was working perfectly fine until suddenly it started to display a black screen that says "file error" in the center when I try to view...
All your pictures are saved on the memory card of your Samsung digital camera automatically.So you can recover pictures from memory card with data recovery software.I have a professional program on my computer that can recover deleted,formatted and corrupted data after deeply scanning your memory card to look for lost data. But you had better have stopped using the memory card of your camera. Because, once the pictures were overwritten by new ones,they are gone for good.
By the way,you may need a card reader to connect the card with computer.Download this program and scan your memory card for free to preview whether your erased photos can be recovered.Get it from http://www.any-data-recovery.com/product/datarecoverystandard.htm
Aug 08, 2011 | Samsung DualView TL225 / ST550 Digital...
Win XP Home will not recognize my Canon A1100 is when it is connected via USB. Camera on or off when connecting makes no difference. If a still image is selected for preview & connecting via USB, no...
Dec 06, 2010 | Canon PowerShot A1100 IS Digital Camera
I have a Kodak Easy Share Zoom Digital camera V1003. I am now unable to take photos because when I switch on the camera all I get in the view is a picture of a black leave. Have downloaded the photos...
hi;
to download your photo from memory Card, you can use a memory card reader, you can by it from any informatic shop, its not expensive, put your memory card in a memory card reader and plug it with USB cable to your computer, click double on icon MY DEKTOP , select the folder right click on,
choose COPY, and then you can paste on the folder MYDOCUMENT;
here the photo of the memory card reader:
Oct 30, 2010 | Cameras
The green light on the back of the camera does not come on when I attempt to download into my computer. The batterys seem ok, I was able to take pictures earlier today and I can view them in the camera
Oct 04, 2010 | Canon PowerShot A410 Digital Camera
Bought a new memory stick. My daughter used her computer to transfer photos and film from memory cards direct on to this memory stick. Everything seemed to be going fine until we tried to view this...
It sounds like you are using a different level of operating system and the preview feature is not available, or the windows media version is out of date. Also check to see if your version supports the file extension!
Aug 18, 2017 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
My Leica Digilux 2, recently purchased and never used before, doesn't appear to be taking pictures. It reads all memory cards (residule photos previously taken) however when taking a snapshot, the display...
Does the menu in the camera work?
You may need to activate some Postview function in the menu. If the camera takes pictures, you should be able to view them in playback mode. There could also be a Preview mode, which requires pressing OK before storing pictures. Preview/Postview should cancel each other though...
Apr 13, 2010 | Leica Digilux 2 Digital Camera
Unable to View Photos/Video - is my SD card to blame?
The question to ask is - is you camera happy with a 2 Gig card? Coming to files on the card you could try one or more of the recovery programs for example www.convar.com for 'pc inspector' see what this manages to pull up. You also try 'Irfanview' which has a little more latitude at file discrimination that a regular editor.
Oct 06, 2007 | Pentax Optio T10 Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
148 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
