Question about RCA R52WH73 Projection Television
Menu pops up continually
The menu won't go away on the screen and runs like I am choosing stuff. You can't exit it just keeps coming back. It changes channels and other setup options.
  • RCA Master
  • 5,138 Answers
Replace contact switches on Front panel board on/off vol- vol+ ch- ch+ Menu First try cleaning them with contact cleaner if that does not work /replace them.
Posted on Jan 08, 2009
The TV menu options keep popping up aprox. 15 mins after turning the TV on.
Do a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 09, 2017 | Televison & Video
My LG T.V's Menu keeps popping up and wont go away, when i try to exit off it, it just pops back up, sometimes it doesnt go away the after a few minutes it does then comes back, I dont have any extra...
The tv manual control buttons board like POWER,MENU,INPUTS,CHANNELS - +,VOLUME - + could be bad and causing this problems.Take the tv aparts,unplug the connection that plug of the mamual pc board functions,the tv will work as normal only no manual buttons functions,if the Menu screen stop poping up,than u know the manual control buttons board is bad must be replace.If Menu it still poping up,than u have a bigger problems,the tv Tuner signal board is the cause and the problems.That the board,that take in the incomming broadcasting cable wire is the problems.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes boards like the manual control buttons board or the tv Tuner signal board.
Mar 23, 2011 | LG W2284F 22" 2ms LCD Monitor - Black LCD...
How to stop monitor menu pop up in my Desktop's CRT Monitor ? The menu pop up keeps coming back and I have to keep exiting manually using monitor menu buttons.
r u sure about model number.bcoz 55v does't come with menu.
replace regulator 7805 near microcontroller if it is model 56v.
Aug 22, 2010 | SAMTRON 55V 15" CRT Monitor
Stupid padlock/main menu keeps opening and closing DELLe152fp
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
Dec 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Screen menu auto-adjust ghost
never try to fix crt monitor you need a new one cos thay are so cheep cost you lots for reppers ,bye an lcd ,,,,nice
Apr 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Menu screen won't go away but i have sound
I am having the same problem too~ The menu screen keeps coming up!
Aug 24, 2008 | Philips 42PF9630A 42 in. Plasma Television
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
RCA R52WH73 Projection Television Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
