Question about Microwave Ovens
I have a Panasonic NN-9850. The oven lamp is out (actually exploded when we boiled some water). The oven seems to work fine except it needs a new lamp. Apart from finding the right lamp part number, I'm not even sure how to replace it since we no longer have a manual.
  • Microwave Ovens Master
  • 9,098 Answers
Well, as luck would have it, you can still download the NZ version of this owner's manual - it looks like it is correct.
The manual does not refer to the bulb, so if there's no obvious removable cover over the bulb (most often on the rear or side)
then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Jan 09, 2009
Panasonic NN-T993SF microwave oven LCD display is out. The keypad is working fine and also the unit is working fine except the LCD display.
The display is part number AEDDHJ5W00AP.
You can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 08, 2011 | Panasonic NN-T993SF Microwave Oven
Will only run for 23 sec, then shuts down. hit reset and it will run for 23 sec again. THis happened after it was exposed to a boiling pot of water. The run time is very consistant before stopping,...
mcdevito75 here, Sounds like the timer mechanism which is most likely transistor board is wet or shorted, see any appliance repair shop in your area for help.Or Check the owners manual for repairs.
Jun 28, 2010 | Panasonic NN-S254BF Microwave Oven
Panasonic NN 9859 Membrane switch
Yes, you are correct. The membrane switch for this model was discontinued. The correct part number for the membrane switch is A630Y5460HAP for model NN 9859.
Mar 26, 2008 | Panasonic NN-T888S Convection/Microwave...
Panasonic Microwave Warm
Replace the h.v. capacitor (the silver can mounted in back under the magnatron) and the h.v. diode and it will be fine.
Hope Ya Fix It!
Jan 30, 2008 | Panasonic NN-S960WA Microwave Oven
Panasonic Inverter Microvave (NN-T990SA) Does Not Operate at Full Power
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 13, 2007 | Panasonic NN-T990SA Microwave Oven
Panasonic Model nn-s252bf.....not heating probably
check magnetron related circuit, any loose contact is there the above problems comes to oven, thats why check all wiring at high voltage section...
Oct 28, 2007 | Panasonic NN-S254BF Microwave Oven
Microwave Ovens Logo
76 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
