Question about HP Color LaserJet 2600n Printer
Replace Supplies red light flashes
The replacement light came on and said black ink was needed. I replaced the ink but the light still flashes and not print.
  • novotechhelp Jan 08, 2009
    I have replced the black toner but the printer (HP 2600n) still says 'replace supplies' I don't think any of the colour toners need replacing but it doesn't tell me which one, if any, need replacing. Please help.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
I used a substitute black ink cartridge and now the red light is flashing and the monitor message is that parts inside require maintenance or replacement. I need to know how to take out this non-epson...
if you light is flashing alternatively, this mean the waste ink counter need to be reset and the waste ink pad need to be replaced.
you will need to download the resetter the link below..
http://inkjetprinterhelp.us/epsonSSC.html
May 28, 2010 | Epson Stylus 680 InkJet Color Printer
One of the two red lights below the X button is flashing. cant print. I need help
Some of ink cartridges is failed.If flashing left light replace color cartridge.If flashing right replace the black cartridge.
Nov 10, 2009 | HP DeskJet 9800 InkJet Printer
Changing color cartridge on my epson stylus color 980 printer.
If you need to replace an ink cartridge in your printer, please follow the instructions below:
To confirm which ink cartridge requires replacement, please use the printer's control panel (there is a black ink out indicator, as well as a color ink out indicator ), or the Status Monitor in your computer.
Red light flashing - Low ink
Red light solid - Out of ink
1. Open the printer cover and press the INK (Cleaning) button for 3 seconds. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8 (to move printhead over to color (if black was replaced first) press the cleaning button once).
8. Press the INK (Cleaning) button once, and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
May 11, 2009 | Office Equipment & Supplies
I have a message that says "Replace Supplies"
When the printer says replace supplies, it means that u have more than 1 supply to replace.
if you print a supplies status page it will tell you which supplies need to be replaced.
Hit the Check mark to go though the menu.
Dec 31, 2008 | HP LaserJet 3600n Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
The red light keeps on flashing
HI-
Turrn off the printer then unplug it for a few minutes. replug it then try pressing the maintenance button once or press and release it, if it doesnt move to position where you can change it press on it again. If this doesn't help. Go to start on your computer, go to setting then control panel, click on printers and faxes( then right click on the printer icon and left click on printing preferences then) look for utility or maintnance tab then there should be an option to replace ink cartridge.
Keep me posted
Sep 15, 2008 | Epson Stylus C43SX InkJet Printer
HP Color LaserJet 2600n Printer Logo
212 people viewed this question
Ben Johnson
