Question about Toshiba Satellite A100-S8111TD Notebook
The screen stays on when shutting off the laptop
When I turn off the laptop, some time the screen stays on, so what I do is lo let the battery go off and turne the laptop on again and showes if I want to start Windows normally
  • 22 Answers
Do you have automatic updates turned on? If so turn it off and see if problem goes away.
Posted on Jan 08, 2009
I have a WF331ANRXAA washer when I turn it on door lock cycles 3 times drum turns slow no water goes in, than it stops and LO shows up on the screen
THE DOOR IS NOT LOCKED MEAN LO
TRY TO PUSH CORRECTLY THE DOOR NEVER TURN IT ON WITH THE DOOR BADLY OPENED OR MISHUT
Oct 24, 2014 | Washing Machines
Polaroid i733 digital camera
Initially, let's try a hard reset by removing the battery. Let it be without batteries for a couple of minutes to about an hour. Thereafter re-insert battery and try again. Additionally, pls verify that the battery is fully charged
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 07, 2008 | Cameras
Battery light flashes and nothing else happens
Yes, the socket broken loose could be your trouble and is common as we are not careful when we insert the plug all the time.
Apr 19, 2012 | Computers & Internet
My computer won't turn on at all, the green light comes on but only a black screen shows. When it was plugged in to power the light wasn't showing that it was charging so took out the battery and then...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
When i turn it on it wont show desk top it stays on a black screen
Does your laptop have its lights on the keyboard even if your screen is black? If it is , try to remove the cables and battery of the laptop. Press and hold the power button for 8 seconds. Then reinsert the cables and battery on the laptop. Turn on the laptop, and if there is no light on screen & keyboard, it means that the power supply or the motherboard has trouble. That is the time to contact Dell support for possible repair or replacement. Otherwise if the keyboard has lights but the screen is still black, that would be a video card problem since the LCD screen is not a separate entity. Just make sure if it has the power button on the screen, it is turned on. That instance would need a video card replacement...
Jul 12, 2010 | Dell Inspiron 1000 Notebook
Dell inspiron 1545 won't boot turn on start up
Unseat and reseat the memory in the laptop one stick at a time in each slot one at a time. Turn on the laptop after each reseat of memory.
If that doesn't work then take out the hard drive and then the dvd drive.
Turn the laptop on again and if you still can't get video on the screen then the motherboard is defective and would need to be replaced.
Nov 30, 2009 | Dell Inspiron 1545 Notebook
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
The problem is with my MSI laptop. When i turn it on the lights for the power come on but then it switchs off again within 5 seconds if it is on battery power and if i use the mains supply the laptop will...
i used to frequently take out the battery on my machine and put it back in over and over again until one time it sparked and made an audible pop. now it only works on ac power. some thing inside your laptop may be fried, or there may be an illegal contact somewhere either inside your laptop or inside the battery. or there may be something on the contacts that connect the battery to the laptop.
Dec 03, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
