Question about Philips 42PFL5603D 42 in. LCD HDTV
Philips tv codes for dish remote
Just got a 42" philips tv for Xmas still have Dish what is the TV code so I can control the 42 with the Dish remote, instead of the Philips remote?
4 Suggested Answers
circuitworld
  • 335 Answers
SOURCE: my philips 42 lcd will
Click here at Philips firmware support center seems like this could be a firmware problem as Philips is known for in the TV repair trade. Download the latest version upload too your TV via connect card or USB see if this clears this problem. If not then its probably the infra-red sensor in the TV which is not working and needs to be replaced. Also be sure there are no parental locks which could influence remote control response...
http://tvtechwork.webs.com/
Posted on Oct 18, 2010
electrotech1
  • 1126 Answers
SOURCE: MY PHILIPS 42" LCD SUDDENLY STOPPED RESPONDING TO
The TV processor is locked up, unplug from wall for 40Min, and it will reset back to normal.
BeckiB_DISH
  • 286 Answers
SOURCE: need remote code for dish network remote to
If you have not found the codes yet, follow the link below. The link will walk you through the steps to program the remote to the tv. They are simple steps.
Codes:
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
If the codes do not work, try this link for a power scan, which will scan the tv for the correct code.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Posted on Jan 21, 2011
BeckiB_DISH
  • 286 Answers
SOURCE: need universal remote control code for maxent 42" plasma tv?
I hope that you have gotten this resolved, but if not, or if you have any other questions, here are the codes and some simple steps to run through.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
246
730
746
Becki Barned
Posted on Feb 02, 2011
Codes for tv remote for dish
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Dish TV remote control code list is given.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 16, 2014 | DISH Network Televison & Video
Dish network remote control and akai tv
Not likely the Dish remote will have that remote code at all in it--some of those sets were made by Samsung so try those codes also.
Jun 01, 2012 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
NEED A CODE TO PROGRAM DISH NETWORK 5.4IR REMOTE TO OPERATE PHILIPS HTS3565D
Hello! My name is Becki, with DISH Network. Programming the remote to the TV is a pretty easy process. I have given some codes that should work to program the remote. If not, please let me know!
566
828
824
Becki Barned
becki.barned@dishnetwork.com
Jul 13, 2011 | DISH Network IR Remote Control
Need remote code for dish network remote to control philips tv want dvr and tv to work off the dish remote
Codes:
Becki Barned
Aug 04, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
Need universal remote control code for maxent 42" plasma tv?
246
730
746
Becki Barned
May 17, 2010 | Sampo PME-42V3 42 in. Plasma Television
Need 13'' magnavox tv/dvd combo code for dish remote
To find the right code first click here.
Next click on the "Remote Controls" section.
Select the type of remote you have (based on the receiver model) to view the remote control users manual.
Hope this helps!
Mar 16, 2009 | Philips Televison & Video
Need code to program dish remote
the dish network code is in the cd that comes with the TV.
Jan 18, 2009 | LG 42LG70 42 in. LCD HDTV
Remote for Dish Tv control
hi! i think remote controller fell down! The remote board damaged and cracked because of that only remote (button two only) not working! you use multi-purpose remote then you switch on DISH TV.
Thank you..........
Jun 17, 2008 | Philips Magnavox Learning Universal Remote
Philips 42PFL5603D 42 in. LCD HDTV Logo
793 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
