Question about Epson RX620 All-In-One InkJet Photo Printer
I put a lighter pound paper in the printer RX620 and it all entered the printer at once (about 25 pages) and is stuck! I can't free it--can you help me?Thanks
    Brigadier General:
  • 5,158 Answers
Unfortuanately you'll need to roll up your sleeves and pull very hard to remove that jam... the manual recommends the proper thickness of paper for the printer and you should stay within those boundaries
Robert
Posted on Jan 06, 2009
What do I do to fix when my RX620 Epson printer tells me that parts within have come to the end of service life?
fault is caused by counter, which counts printed pages for reason of possible overflow of waste ink pads. To reset counter a free tool is available under::
http://www.ssclg.com/epsone.shtml
this tool has also other advantages of e.g. overdubbing cartridge codes ....
a german instruction for resetting the counter is available here:
http://www.druckerchannel.de/artikel.php?ID=1116&seite=13&t=schritt_7_zaehler_zuruecksetzen
make sure to have removed and replaced waste ink pads:
http://www.octoink.co.uk/pages/Epson-RX620.html
start program, choose printerport which is used for Epson rx620, choose Epson model rx620
close active window of program ssc -> program will be available by icon in right lower corner.
switch on printer
right mouse click on program icon in right lower corner will open options:
http://www.druckerchannel.de/artikel.php?ID=1116&seite=13&t=schritt_7_zaehler_zuruecksetzen#
choose according to picture
switch off printer / switch on printer
in case of not working at once retry
Jul 14, 2012 | Epson Stylus Photo RX620 All-In-One InkJet...
I think i have a fuser error. When I print something the right side of the paper is very light in color. If I print multiple pages, it gets lighter by every page.
Put paper in the manual feed tray. Print. When the page gets half way into the printer, open the cover. Remove the toner. Look down at the paper. Is the right side lighter than the left? If yes, replace the toner cartridge. I don't believe that a fuser could cause your problem.
Aug 11, 2011 | HP LaserJet 4240n Printer
All printed pages come out with random "V" type
Check to see if there's anything stuck onto the fuser rollers. It sounds as if there may be some residue dirt that prevents the fuser to do its job. It may be that someone tried to print on a self-adhesive paper that was not meant to go through laser printers, and somehow a triangular shape got stuck on the rollers.
On the other hand, if this V shape is just a wrinkle that's different on every printout but preserves the general V shape, then you may be looking at the paper guidance plastic "fingers" inside the paper tray. See that the paper is freely movable and it's not pressed too hard. Also, see that you don't use lighter paper than 80g/m2, although printers say they can handle lighter paper, 80-120g/m2 is still the best thickness for lasers.
If you found this post informative and helpful please vote for it with a Thumb Up. Thank you.
Jan 18, 2011 | Samsung CLP-610ND + Demo Laser Printer
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
Ink cartridge not moving
it is a problem of carrage motorneed to replace
Sep 05, 2009 | Epson RX620 All-In-One InkJet Photo...
No shadow density in photograph printing
If you haven't been printing for 6 weeks, your print head is clogged, which is why the print quality is poor. Turn your printer on. On your computer, go to START, then SETTINGS, find PRINTERS AND FAXES and click on that. A window will open and you should see your printer. Right click on it, then click on PROPERTIES. A window will open, with several tabs. The one you need is MAINTENANCE. Open the tab and click on CLEAN PRINT HEAD. I think there are 2 options, cleaning and deep cleaning. Click on deep cleaning. You should hear the printer rumbling, then, when it finishes, it should print a page with 4 colors: black, cyan, magenta and yellow. If the colors come out right, you're done. If not, repeat the cleaning until you get a satisfying result. Just bear in mind that cleaning the print head uses a lot of your ink, so I suggest you put the refilled cartridges when performing this operation.
Also, to avoid getting in this situation again, I suggest that you print one page, at least once in 10 days. That way, your print head should always work fine.
If you found my answer helpful, please vote, it really means a lot to me to know weather I am helping someone or not.
Jan 13, 2009 | Epson Stylus Photo® RX620 InkJet Printer
Epson Stylus Photo RX620 Printer
Hi
If its E-90 error then there is a hardware problem with the printer already.
Hope this helps
Oct 13, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
HP4250 printer - 25-30 pages stuck
Sorted it myself in the end.
Unscrewed the hinged plate covering the transfer charge roller(?) to release pressure on from the 25 sheets of paper.
Then pulled the paper back through.
Re-assembled and tested OK
Jun 25, 2008 | HP LaserJet 4250n Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
