Question about Panasonic DVD-RV26 DVD Player
Will i be able to use my old panasonic dvd-rv26 for a tv
Tuner after digital transition
  • 24 Answers
From the information I found, it does not have an ATSC tuner that you need to pick up the digital over the air TV signals. You will need one that does, check this page:
Posted on Jul 20, 2009
How do i set tv up with regular antenna
You are not stating what type of TV you have. If it is an older CRT or even some older LCD flat screens, it may only have an analog tuner. All TV stations today are broadcasting digital signals and if you do not have a digital tuner in the set, you will need an adapter box to use an antenna with the set. They were widely sold around the time of the analog-to-digital transition, but are harder to find anymore.
Oct 20, 2015 | Televison & Video
Will the Panasonic DMR-E30 DVD Recorder replace my STB to receive the digital free to air stations on my tv?
Only if it has a built in digital tuner, and, if it does, the digital is only SD (standard definition). If not, you would still need the set top box to receive HD (you could connect the box to the DVD recorder (for HD and/or SD) as required if you wish to record channels). Most set top boxes have both SD and HD channels in their tuners, so it would most likely be the next best option if your DVD recorder does not have a built in digital tuner. You can check your DVD recorder's on screen setup menu to see if digital services exist within it. Either way, keep your set top box just in case.
Oct 06, 2011 | Panasonic DMR-E30 DVD Recorder
I would like to make my Panasonic DVD-RV26 region
Thanks for using FixYa. There are the following two methods to make it region free---
Method 1:
No disc in tray; Press STOP; Press SET-UP: KEY IN 3, 8, 8, 8, 3 then 0 for zone free
Method 2:
1. Remove DVD/CD from your drive.
2. Press the following keys on your remote: [Setup] [1] [>=10] [6] [4] [3] [8]
3. A new menu option will appear – named other followed by four stars. Use Codes: 3192 -> Multi-Region Enable
Please do accept the solution if the issue is resolved or else revert for further assistance.
May 01, 2010 | Panasonic DVD-RV26 DVD Player
DVD recorder has stopped picking up a signal from the tv.
Double check connections first and try using the factory settings reset, before replacing the card.
Mar 01, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Digital TV
It does have a tuner built into it.
It is not a hd or digital tuner.
<A href="">
Feb 23, 2008 | Panasonic PV-D4752 DVD Player / VCR Combo
Panasonic DVD-RV26 DVD Player Logo
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
