Canon C3200 imagerunner error code
Canon C3200 error code E004 0002
  • tony337 Jan 13, 2009
    I have two other questions when I print to my copier over the network sometimes it acts as if it is off line 5 or more min. will go by then all of a sudden it will print the job. My next question is i would like to upgrade my memory from 128mb to 256mb in my imagePASS-C1 processor what kind of memory should I purchase.
    I have 3 questions and only 1 has been answered
  • 818 Answers
E004 Triac or fuser won't shut off
Posted on Jan 13, 2009
  • 19,396 Answers
On Canon IR series, E004 codes indicate a power supply issue.
Sometimes you reset this just by unplugging the machine for a while, if the code comes back, the power supply or a shorted power switch may be the cause. Parts must be tested.
signal of the power supply is not detected.
Error is displayed when signal does not arrive for 3 sec continuously or short circuit is detected in the triac.
Possible cause:
The main thermistor is faulty.
The sub thermistor is faulty.
The fixing heater is faulty.
The power board is faulty.
The DC controller board is faulty
Thermistors and heate may be tested reading continuity.
Once the fault is fixed there is a service procedure to fix the error, I think it is Copier>>Function>>Clear>>Err
Regarding RAM, your Imagepass C1 can be expanded to 1.5 Gb. And should have 756 Mb RAM (768) extension RAM.
512 Mb extensions are the only ones available.
See 0529B002AA, IRC3170, IR 512MB EXPANSION RAM C1,
Or order from Canon calling the number on manual.
  • Ginko
    Ginko Jan 13, 2009
    I answered two of your questions, about the network delay , that may be for many reasons, an to a certain extent some delay is normal , particularly if you use wifi connections.
    I charge $80 plus plane ticket to go onsite and fix it.
    I post again my previous comment, in case you lost it .
    Note that triac and fuser solutions are wrong, they are explanations for error 004 on different models.
    on Canon IR series, E004 codes indicate a power supply issue.
    Sometimes
    Possible cause:
    faulty
    Once
    See https://www.executivecolor.com/item.asp?...">0529B002AA, IRC3170, IR 512MB EXPANSION RAM C1,
    Master:
  • 413 Answers
For the printer there are two heating lamps through the upper fixing roller in the fixing unit, I think one of them is blown. There are the e004 is telling you that one of the heating lamps is blown. It would probably be best to call a tech. To come fis the machine as the E002 code may require some new switches to be installed on the boards inside the machine.
The delay in the printer could be caused by a couple things. First if the printer is on a wireless network ensure it is recieving a strong signal from the switch or router, If not it sounds like the computer the printer is hooked up to needs to be restarted or have its network drivers updatded. Unless the printer is hooked directly to the network. If it is then the drivers on the machine itself need to be checked and updated.  Also on the wait to print, Make sure the printer is not having problems warming up.
  • 3,037 Answers
Hi tony
Are you experiencing No Power / Boot Failure with this problem?
When a overcurrent or a short to ground occurs in the machine such as a motor binding or a wire shorted to the frame of the machine, a fuse on the DC Fuse PCB should open to prevent further damage. The DC Fuse PCB Assembly (FG3-3020-020) is located at the rear lower left of the machine mounted on the DC Power Supply. Please check the fuses here and then look for the short leading away from this fuse.
bestdarngood
    Sniper:
  • 59 Answers
Hi you can give this place a call and let them kno your problem
Elite Printer Services... (918) 583-5483
    President:
  • 2,976 Answers
Change your printing preferences from spooling to direct print. Also, print the first page first not last. These steps will release the documant faster.
    President:
  • 2,110 Answers
You need to load the copier drivers into your server you can down load these drivers from canon website /or your network outlet is not setup
E000020-0281. I have this error in my printer model canon C4080
Canon imageRUNNER C3200 Copier 0281 e000020 ...
www.fixya.com > ... > Canon > Canon imageRUNNER C3200 Copier
E000020-0281 Hi in relation to your question about the error code (it seems to be from aCanon iRC3220 printer), I have found this webpage whch looks as if ...
Oct 08, 2015 | Canon Office Equipment & Supplies
Error code canon copier
this error code it shows that there some particle onside the machine you need to clean and to change cyna developer
Feb 22, 2010 | Canon imageRUNNER C3200 Copier
Problem on Canon imageRUNNER C3200 Copier Error Code We have an error code of e000020-04b0
replace black drum it is reaching the end of its life also make sure your machine has the latest software version as drums will last longer if it has have seen drums reach 700-800%
Nov 04, 2009 | Canon imageRUNNER C3200 Copier
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
Canon iR C3200 E00020 02d0
check or change the magenta drum unit
Jul 29, 2009 | Canon imageRUNNER C3200 Copier
Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Mar 20, 2009 | Canon imageRUNNER C3200 Copier
Error code on Canon ImageRunner C3200
check the yellow drum unit, laser shutter or the plastic actuator on the right side of the front door, also check the pattern reading unit for dirt
Feb 19, 2009 | Canon imageRUNNER C3200 Copier
Error Code
Called local service technician.
Mar 26, 2008 | Canon imageRUNNER C3200 Color Printer
Canon Imagerunner C3200 User Manual
what driver do I need for a imagerunner 3200 with fiery and where can I get them
Jan 12, 2008 | Canon imageRUNNER C3200 Color Printer
Help
Are you needing help with an error code for imagerunner c3200?
Oct 07, 2007 | Canon imageRUNNER C3200 Copier
k24674
