Question about Cyberhome DVR 1600 DVD Recorder
DVD malfunction The DVD does not respond to any key pressing
    Problem Solver:
  • 5 Answers
Check to see if there is power first second if there is unplug unit take off the lid and try using a can of compress air. and thoughly spray behind the face plate if notice any dusts particles behind the face plate carefully remove by flipping clips and use 100% rub alconol which can be bought at the drug store. Then allow drying tme. the buttons may be worn or clogged hope this helps
Posted on Aug 11, 2007
How do i link my radio shack gamer-pro remote to my dynex
1. Turn on the device (for example, DVD player) and, if needed, load media (for example, DVD).
2. On the remote, press a device key (that is, VCR/DVD, CBL/SAT, or TV). 3. Press and hold P until the red LED blinks twice, then release.4. Enter the first four-digit code for your device.
The LED blinks once as each digit is entered. If the code is correct, the LED blinks twice.
NOTE: If the LED does not blink twice, repeat steps 2 to 4 and try entering the code again.
5. Aim the remote at the device and press Power (or Play, if it does not have a Power key). The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works.6. Repeat steps 1 to 5 for each device you want to control. For future reference, write down each working device code in a safe place.Code search Method
1. Press TV once.
2. Press and hold P until the red LED blinks twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power. The remote sends IR codes from its library to the selected device, starting with the most popular code first.
5. If the TV responds, go to step 6. If the TV does not respond, press CH+. The remote will try the next code. Continue until the TV responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED blinks twice.
7. To search for other device codes, repeat steps 1 to 6, substituting the appropriate key for the device.
Oct 03, 2011 | Dynex DX-L19-10A LCD TV
I would like to know the code for my dvd player its a RCA please
Hello
Setup code for RCA with Philips SRP2003/27 is:
2351
[1] Make sure the receiving device is able to
respond. E.g. when you try to repair the Play
key for your DVD player, make sure to insert
a DVD into the DVD player otherwise the
Play key is not able to function.
[2] Select the device
that you wish to
operate (e.g. DVD).
Press the (DVD) device
selection key to
select DVD.
[3] Keep keys (1 & 4) and
pressed
simultaneously for 5
seconds
The red Setup
light lights
up. The remote control is now in setup
mode.
8 EN
[4] Press and hold the key that does not
function and immediately release it when
the device responds.
* If the key still does not function as expected,
try pressing it again for a longer period of
time.
[5] Press the (DVD) device
selection key twice
to save your settings
and exit setup
mode.
When no key
is pressed for 5 minutes or more, the
remote control will exit setup mode,
automatically saving all your settings.
OK.
Aug 15, 2011 | Philips SRP2003/27 Remote Control
I am trying to get my philips universal remote to workcr with a sony dvd/vcr player..how do i do it?
please go to the below website and select the model of your remote.
An page opens in that you have REMOTE CONTROL CODE FINDER,click it
Choose the device type and device make it gives the code for your remote.
Then follow the procedure given below,
1 Turn on the DVD ( The DVD should play ).
2 Select DVD on the remote (= Press the device key for which you are programming the remote ) :
keep the key pressed for 5 seconds until it blinks twice and then remains lit.
3 Enter the given four-figure code for your brand , using the digit keys .
– The DVD key will now blink twice and then remains lit.
• If the DVD key blinks once , the code has not been entered properly or
The wrong code has been entered. Start again from step 2.
4 Press and hold the “ standby/power on” key and immediately release it when the TV
switches off (standby).
– This may take up to 30 seconds.
5 Turn on the DVD and check if you can
operate all needed functions on your DVD
– Make sure the receiving device is able to respond and accept the desired command .
6 Press the DVD key twice to exit setup mode and save your settings.
– When no key is pressed for 2 minutes or more the remote control
will exit setup mode automatically.
• If the device does not respond at all or not to all of the key commands or if you cannot find
the code for your brand, enter ‘0, 0, 0, 0’ in step 3 and continue with step 4.
The remote control will now search the full database for a code that works with your DVD
Full database search may take up to 15 minutes.
thanx
Jul 21, 2010 | Universal Remote Control Hampton Bay...
Locked
If the calculator has locked up you should perform a reset.
  1. Press and hold the [C] (ON/OFF) key
  2. Press and hold the [LN] key (third key from the left on the top row).
  3. Release both keys simultaneously. T
  4. The calculator should display "0.00" (if the number of decimal places is set to two.)
If that does not bring it to life you should perform a full memory reset
  1. Press and hold the [C] (ON/OFF) key.
  2. Press and hold the first key from the left ( the Square root x key) and the first key from the right (the SIGMA+ key ) on the top row.
  3. Release all three keys at the same time.
  4. Calculator should display "ALL CLr".
  5. To clear the message press the [C] (ON/OFF).
  6. The calculator should display "0.00."
If the calculator does not respond as expected,
  • Remove the batteries, and
  • with a metallic coin (and what coin is not metallica) short-circuit the calculator's electrical terminals.
  • Maintain the coin for about ten seconds.
  • Replace the batteries (preferably fresh ones) respecting the diagram inside battery compartment.
  • The Calculator should display "ALL CLr".
  • To clear the message press the [C] (ON/OFF).
  • The calculator should display "0.00."
If the calculator does not respond to the foregoing procedures, remove the batteries and leave them out of the calculator for 24 to 48 hours to drain capacitors.
If it continues to malfunction, it will need to be repaired. One repair shop in Pennsylvania, USA has a website at http://www.fixthatcalc.com. You should contact them.
Apr 11, 2010 | HP 20s Calculator
How do i reboot
If your unit was freeze and did not respond to any key you press, you may try to press the power button for 5 seconds, the unit will automatically turn off, on this state press again power button once.
Hope this helps
Nov 29, 2009 | HP Pavilion dv6000z Notebook
I need a remote code for a emerson lcd lc195em82
1. Manually turn on the component you want the remote to
control (TV, VCR, DVD, satellite receiver or cable box).
Note: If you press an invalid key during the Auto Code
Search, the remote does not respond and the illuminated
ON•OFF key does not blink. If you do not press a valid
Auto Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF,
GO BACK, PLAY, REVERSE, STOP), the search times out
after two minutes. When the search times out, the illuminated
ON•OFF key blinks four times and turns off. The last
programmed code under that component key is retained.
2. If you are programming your TV or satellite receiver, go
directly to step 4.
3. To program the remote to control a VCR or DVD. The
VCR•DVD key can control only one component, either your
VCR or your DVD. To program your remote to control
either your DVD or your VCR, you must first put the
remote in the proper programming mode. Follow these
directions before proceeding to step 4.
a. Press and hold the VCR•DVD key.
The illuminated ON•OFF key
turns on.
b.While holding down the
VCR•DVD key, press and release
the number 2 key on the keypad to
control a VCR or the number 3 key
to control a DVD. The illuminated
ON•OFF key blinks, and then turns
back on.
c.Release the VCR•DVD key.
blinks four times and then turns
off. Your remote is now either in
VCR or DVD Programming Mode,
depending on which you chose.
Proceed to step 4.
4. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you wish
to program. The illuminated ON•OFF
key turns on and remains on.
5. While holding the component key
down, press and hold the ON•OFF
key. The illuminated ON•OFF key
turns off.
6. After holding down both keys for
three seconds, the illuminated
ON•OFF key turns back on.
7. Release both keys. The illuminated
ON•OFF key remains on.
VCR•DVD
VCR•DVD
VCR•DVD
ON•OFF
(BLINK)
ON•OFF
(BLINK)
ON•OFF
ON•OFF
(BLINK)
SAT•CBL
VCR•DVD
TV
TIP: Throughout the programming of each key, be sure to
keep the remote pointed at the IR sensor of the component you
are currently programming the remote to control.
8. Press and release the PLAY key,
then wait five seconds to see if
your component turns off. If your
component does not respond,
continue to press the PLAY key
every five seconds until your
component turns off. Each time you
press the PLAY key, the illuminated
ON•OFF key blinks and a block of
10 codes are sent to your component.
This process continues until all of
the codes in the Code Lists have
been searched. (If your component
has not turned off after all codes have
been searched, the illuminated
turns off. The Auto Code Search
Entry method is exited.)
PLAY
ON•OFF
(BLINK)
10
11. To confirm that the component key is programmed with the
correct code for maximum functionality, test the component.
Attempt to control a variety of the component’s functions
with the remote. If some of the features of your components
do not work, try programming the remote with a different
code in the list until you find the code that allows the remote
to control the majority of your component’s functions.
Different codes can provide different levels of functionality.
Mar 26, 2009 | Televison & Video
Remote control
turn on the dvd player
press and hold the 'enter' key and the '1' key at the same time
remote will start to work again
Sep 14, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Power malfunction
I think these are just junk unfortunately. I have tried multiple times with a reset problem on mine - I think these just have faulty power supplies?
Feb 05, 2008 | Protron PD-DVR100 DVD Recorder
Cyberhome DVR 1600 DVD Recorder Logo
24 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
