Question about Rode NT5 Professional Microphone
Hissing from one of the two NT5 mikes
In a laptop recording stereo setup one of my two NT5 stereo microphones has a strong continuous hiss that will not go away. It hissed the 1st time I used (2 months ago); but went away when I returned it to the store where it did not hiss and I have subsequently have been able to record with it. Now the hiss has returned. I have tried swapping the microphones between the cable and the hiss moves with the microphone. Any suggestions? Crossrich
  • natasinfecte Jul 14, 2008
    Cheers! I bought this pair 3 weeks ago. Yesterday I was recording and had the same problem. One sounds OK, the other one is a continuos hiss. Recorded with firepod pre.
    Thanks
  • 113 Answers
Have you concluded that it is 1 of the mics?if mics are ok you need to purchase a mic pre.
Posted on Aug 09, 2007
How can I solve a problem on my pc wiith regards to it's hissing sound
In most cases it sounds like the fan is having trouble. Get a can of compressed air and clear out the air vents on the sides and back. It may spit out a ton of dust, and it should help improve the hissing sound. If it needs a better cleaning, you may need to remove the lower part of the casing.
Aug 21, 2014 | Toshiba Computers & Internet
ASUS G73J line in option does not work
in the recording audio settings when the new line in device is plugged in select that as default, then it should revert back to old setting when it is not in use but select the default when you plug it in, however there should be an option in the audio settings to adjust the hissing you hear, see if you do not have some boost in the settings turned on, i know making the line in boost will create hiss
Jul 29, 2013 | ASUS G73JHA2 Notebook
Static Noise
Is it a hissing noise or a distorted crackling noise? If it's a hissing noise then it's due to a bug in Windows that adds 30 dB of gain. It's easy to work around, though: Go into Recording devices, Properties button, Levels tab, right click on the level number so that it shows in decibels, and then adjust the level to 0 dB. It's supposed to be at 0 dB but Windows 7 defaults it to 30 dB for no reason. This isn't a problem on Windows XP or OS X.
Jan 04, 2012 | Samson G-TRACK USB RECORDING MICROPHONE...
I got a rode classic II with avalon m5 mic pre. So when i crank up my mic pre to 60 n i can start listening some hissing from my monitor...or is it normal for a valve mic coz when after recorded with this...
The hiss is caused by your monitor system level and your preamp gain being so high. At high gain settings, a preamp is going to get noisy, and tube mics have a higher noise level to begin with.
If you can't hear it on your recordings, then it's not a problem.
Sep 17, 2011 | Rode Classic II Professional Microphone
POWER CHARGING WITH HISSING SOUND AND POWER NOT BEHAVING AS DC BUT AC CHARGING TURNING THE POWER ON AND OFF
I would strongly suggest you cease using the power charger. There is definitely a hardware failure inside of it. Continued use may result in it frying your laptop. -Ravi Shanghavi
Aug 19, 2010 | Compaq Computers & Internet
When I record into a recording program only one half, I believe the right side records. Why is that?
You need a adaptor jack. The mike probley has a mono (2 conductor) plug and the recorder probley has a stereo (3 conductor) jack.
If you take the mike to radio shack and explain the issue they'll sell you a $5 adaptor.
Apr 17, 2010 | Philips PH62080 Uni-Directional Microphone...
Hissing sound when recording
hissing sound when recording is due to old microphones or frequency interuptions if you have a wireless mic i suggest you to find a new mic, or if you have singstar use their mics
if it is video recording then buy a new camcorder
Jul 07, 2009 | Electronics - Others
Hissing noise in the microphone.
my mic was plugged in the front panel of my pc. it was producing that hissing noise. then i plugged directly into the sound card at the back of the pc. problem solved.
Mar 18, 2009 | CAD Microphones GXL1200 Professional...
Microphone hissing sound
That sounds alot like the microphone booster in control panel. Depending on what version of windows your are using, you can just open the sound control from the taskbar and go to the advanced settings and uncheck the setting "microphone booster". Adjust microhpone volume accordingly.
Dec 31, 2008 | Yamaha WaveForce 192XG Sound Card
When I record using my microphone I hear "pops" and 'hissing" when listening to the playback. What can I do to prevent this? The moment I plug in an external mic (a Sennheiser) a low level rumble starts...
These mini video cameras are great for a lot of reasons, but the drawback is the tiny buttons and connectors, like the microphone input. It's probably actually a stereo microphone input.
If it is stereo (check the manual), then try using a stereo adapter, where you plug the adapter into the stereo mic input on the camera, and then plug the single microphone into only one side of the adapter ... then copy the audio to the "missing" side later in production ...
Alternative: record the audio separately onto a decent quality audio recorder with proper microphone jacks, then find the corresponding audio and synchronize it in software production. This is often how professionals do it, and one of the reasons you see the familiar "clapboard" snap at the beginning of movie shoots ... clapping your hands on camera right before you shoot will give you a visible action that will correspond to a peak in the audio soundwave that you can match up to synchronize the audio once you put the video and audio into your computer.
Another alternative - new item these days is an audio interface for video cameras that is basically a small black box that mounts onto the video camera or tripod, plugging into the tiny input on the camera and providing XLR microphone inputs ... just go to Borders and pick up any magazine on video production, you'll see them advertised all over the place ...
Good luck, hope I have helped in some way!
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Dec 18, 2007 | Sony Handycam HDR-SR1 HD Camcorder
Rode NT5 Professional Microphone Logo
168 people viewed this question
Top Rode Audio Players & Recorders Experts
Michial Gueffroy
Don Hart
Tom Chichester
Are you a Rode Audio Player and Recorder Expert? Answer questions, earn points and help others
